Hi Max,
absolutely wonderful plugin!
I’ve start using the Pro version recently and I’m very happy you brought this functionality to Zbrush.
Here are some findings that might help you for the future versions:
BUGS / ISSUES:
I experienced problems with the GoZ command - sometimes it sends the wrong models to 3dsmax. Sometimes it send the right models but the UVs were missing.
Also in order to use the standard GoZ button from the Tool palette I had to close Zscene Manager first. If Zscene manger is on the screen and I press some of the GoZ buttons like All or Visible, nothing happens. As soon as I close Zscene Manager, the GoZ process starts and the models are send to 3dsmax.
FEATURE REQUEST:
Batch rename, add suffix or prefix:
The batch rename tool is wonderful. I would really like if you can add “prefix” and “suffix” features.
For example, to export from Zbrush for texture baking in Substance Painter I add “_high” at the end of each exported subtool and “_low” to its lowpoly corresponding part.
Thanks once again for this awesome plugin!
