Hi dear friend aminuts
Problem is resolved, version 3.35 not salve good .obj, I run new version 3.38 and very good .obj
This is my first idiot[k]not
DruidĀ®
P.S. Who I get this your 3d effect aminuts (your image in page 1 this topic)?
DruidĀ®
Abyssis,
instead of loading the tool, and making polymeshā¦do this exactlyā¦
if that doesnāt work, I hope perhaps Aurick can.
Cool Druid, I am glad you found the problem.
in knot 3d you can make the obj 3dā¦do that before exporting the obj.
you can also play with the depth settings in knot3d in the 3d section on the bottom right.
Iāll try to post a picture later.
Ok Druid, and anybody wanting to play with thisā¦
The mesh created is ok but unstable when trying to divide so to import it to z2 and get it to work properly follow the directions I gave to Abyssis above from step
6 and you should have no problems messing around with the objās.
Hope this helps. :rolleyes:
OK dear friend aminuts
My problem now is working in ZB2, Iām a newbie in this software, but Iāll go to learn with the time
Thanks for all attention.
DruidĀ®
Sorry to take up the bottom row tonight guys, if i could control that I wouldā¦however trying to help someone.
ok Druidā¦here are the how toās in z2ā¦
hope this helps Druid.
Hi Animuts
You have a curious ZB color interface
Are you daltonian
Pilou
Ps Cool tuts
Maybe you must private Mail Abyssis for donāt miss these super tuts!
Thanx, my dear Frenchie-friend, is not necessary to contact me privat
I read and understand the posts, but: I tried everything possible and my results are UGLY⦠(in this special case, sure, everything else is fine 4 me)⦠I really think, my copy of ZB2 is wrong⦠(Or copy of my old-sklerotic-brain maybe???) The same result I get, if I try make 3D-objects from alphasā¦
Hi Abyssis
Can you just show what is your 2D draw for the Make 3D Alpha ?
For make a similar try
Maybe itās a general prob :rolleyes:
Pilou
ok, Frenchie, 1.) I will post it later, thank you 4 nice patience 2.) Wizz this (undocumented) technique (set merge on, set weld to 0.01 and set tri2quad to 45) i got now usable result
BUT: how did I knew it??? ā aminuts GOAL
Yes Frenchy my color scheme is a bit different hehe, I need to change it again as it is getting old. :rolleyes:
Cool Abyssis I am glad you at least got the ztl I posted to work ok. I too would like to see the alpha and see if it does the same for meā¦maybe we can find a way to make it work.
thx, aminuts-fella How did you found this method? I am not beginer, but⦠One more time: thank you very muæh
@Pilou: alphaBrush No2 -> make3D -> and this is the strange result :eek:
Hi Abyssis
Not for me this time :)(unified or not)
But I have the 1.55b and the Alphas seem are different, here the same alpha has N°"01" for name
Maybe you have a bad regulate by default somewhere?
Pilou
Hi aminuts!
Fine thanks for tuto dear friend, fine fine thanks you are a greater ZB friend
I try your tuto now, after time I will post my results!
DruidĀ®
I think, I go crazy, Pilou
Try number three, ok?
OK 3D Knot in ZB2, finally
This is one test
Thanks aminuts for all,
DruidĀ®
Hi Abyssis
With the tortured Alpha 3 (2 for the 1.55b)
I canāt make the same :qu: (separated stars)
Even with the Mesh Smooth = 1 !
If MS = 0 itās the cuboid function !
So itās a little mystery
Pilou
Hi Frenchy Pilou
beautifull HAMBURGUERS, ahahahhahahah
DruidĀ®
http://www.pims.math.ca/knotplot/download.html
looked,but did not see a link anywhere to this site-an excellent free app.
