[Searching] Celtic Knots ZScript
hi Druid,
yes I saved as obj. if you have troubles just let me know and i’ll give ya a step by step from Knot3d on how I did it.
Sorry Animuts with the demo any extern files can be loading!
Pilou
oh nooooooooooo Frenchy…but you can load tools? I make you some as I would love to see what ya do with them! :smiley:
arghhh ok Frenchy, and or anyone interested…this is the only one I could crunch below 200k…
if you want some others to play with let me know and I can email em to ya…i have a package of 6 that is about 1.2m or i could send individuals but i will have to post a pic i reckon for choices…tomorrow perhaps.
anyway Frenchy I did it in 1.55 as a ZTL so I hope you can try it anyways.
4frenchy1.zip
Sure like that it’s possible !
Pilou
Thx Animuts
You see I can :slight_smile:
Pilou
Ps Frame is the knot with the Zplace of Cameyo :slight_smile:
Background is the Texture Reflect 04
Frenchy, that twisted crochetwork frame is
incerdible…knew you would do something in this thread…; )
Dickie
Hi Dickie
With the Zplace Script by Cameyo it’s a Game’s boy :cool:
3 second realized !!!
And the result can be a real 3D object :eek: :eek: :eek:
Zplace2 by Cameyo
You can take any object 3D and control your way like a Logo Tortoise with the Numeric Keyboard ! (and a lot of crazzy another possibilities)
The more funny best Script after Projection Master :cool:
I only use this script :slight_smile: Look in my signature :slight_smile:
Pilou
woohoo Frenchy!!
I had a feeling the knots would look cool Zplaced.
I love that border!
Hi friendZZ and expertZZ, what the f***d hell are the artefacts every I make polymesh or 3D-object from alpha???
PLEASE ALL LOVELY YA´LL GUYZZ HELP ME, I GO CRAZY :eek: :eek:
Abyssis
is the alpha a flat black and white or is it a shaded alpha?
I sometimes have problems with shaded alphas when making 3d, they have weird stuff like you have above. Maybe zooming in on the alpha in those trouble spots will provide some answers?
Hi, aminuts,
strange one is, this picture is from your tool and I made polymesh only (because I tried to divide – if not, object is broken in small objects, you know the effect…) What now???
Hi friends.
Oh no, look at this message in tools import from .obj: Error encountered while importing a file
I don’t know what’s happening my friend. please help me.
Thanks for all,
Druid®
P.S. My machine is one Pentium II 400 mhz, 256 Mega RAM, running Windows XP Pro, and I use ZB2.
P.S. French Pilou fantastic work :smiley: , to be continued my friend :wink:
Abyssis, did you use the import settings I posted? I didn’t have any troubles…oh but I used the obj file…let me try it with the ztl file and see what happens and see if I can’t fix it…
having said that…before I get a chance to do that…try saving the ztl as an obj…reimport using the settings I posted earlier and troubles should dissolve.
EDIT: Ok Abyssis I tried my suggestion above and all works well…so try that…see pic
Druid,
are you trying to import an obj created by the knot program? it works for me and i imported it into both z2 and 1.55.
when i get a second I’ll check out the knots program to see what settings I used to make a knot and export it for ya.
ok im hooked or just loopy im not sure. however these knots are alot of fun so heres my version showing that aminuts method does work.
aminuts, my dear friend,
I appreciate your patience, but: this is the result everytime :rolleyes:
(I don´t know, what´s wrong…)
aminuts, what I will say with: I think, my proggi is wrong and I don´t know where, what and why…
:confused: :confused:
Pixolator, Aurick, friendZZ, can U help me???
Hi Abyssis
First Are you Sure you made that Animuts said : Weld 0.1, Tri Quad over 45 etc
Else have you try that ?
Load the model of animuts in Zb
Make nothing , just export it
Re import it !
In general Zbrush clean the model :slight_smile:
Pilou
Ps You can try also Load the Model in Wings3D a free prog who can clean the model (unify the normal, clean up) :slight_smile:
And re import in Zb!
Pss But you right I have the same that you
I have made an Unified skin and the same defaults are appeared :slight_smile:
So the model is maybe not absolutly entierely clean !
(but me with the demo I can’t make that I say above :smiley:
