Questions & Troubleshooting for ZBrush 4R8
@artmaker
Useful vid. Make sure to link that to Support when you make your ticket. Remember they’re going to be busy this week, and their default assumption is going to be user error (because in fairness, that’s what most problems turn out to be), so you’ll have to be patient and cover some of this same ground with them again.
Good luck!
@Spyndel
Thanks. Yes I included the link with the ticket.
I appreciate the insight.
@artmaker This is weird. I think I know why You can’t get Your UMesh. But i’m not sure why this happening with Your model (maybe it’s hidden but not deleted subtools, maybe it’s self intersecting surface).
Look at these parts:
I think those are open polygons. Or something similar. In general Boolean fails when something similar happens in other applications.
Could You try to do very simple example:
  1. Ctrn+N
  2. Draw Sphere3D
  3. T (Edit mode)
  4. Make Polymesh3d
  5. Go Subtool -> Append
  6. Pick Sphere3D (or any other basic 3d mesh)
  7. Move it or scale so it intersect with first one
  8. Switch Subtool mode to Substraction (or intersection)
  9. Switch on Live Boolean
  10. Make Boolean Mesh
p.s.: I only could respond in 8-10 hrs from now, sorry
@S-ed
He says he’s tried the operation with many different objects, not only the one in that video.
The thing is, the “make boolean mesh” actually works shockingly well. It’s just not that difficult to use (in most cases). For the most part, if the preview is working the mesh should generate. If there’s a real problem (like trying to do live booleans with the parametric primitive geometry), the preview will simply not work and you know you’ve got an issue. I’ve done some really crazy stuff and not managed to break it yet (although Ive gotten some real Brundlefly results on occasion).
That said, if you wanted to confirm it’s a local issue and not an object issue, I’d be happy to download a file that artmaker puts up and see if I can process it–unless there are Mac generated .ztl to Windows generated .ztl issues that I’m not aware of.
S-ed,
Thanks for the suggestion. That does look odd. I have done the operation on several objects with the same results (or lack of results).
But I did try following your instructions exactly – 2 spheres.
Still the same result. No new mesh. Thanks and Have a good night’s sleep :slight_smile:
anigroove
I did uncheck the multiple transpose function in Gizmo on all subtools, but no change?
Basically you have to make sure to deselect all subtools by Ctrl-Shift-clicking the canvas before you toggle off that icon.
See video by Michael Pavlovich :
[video=youtube_share;pNbhvhNFWMw]https://youtu.be/pNbhvhNFWMw[/video]
Michael Pavlovich has a complete playlist about 4r8 new features : check it out here: [https://www.youtube.com/playlist?list=PLkzopwqcFevY_yAkRTXflCN5KXYmcUvhi
Hope this helps …
](https://www.youtube.com/playlist?list=PLkzopwqcFevY_yAkRTXflCN5KXYmcUvhi)
Người tuổi Hợi khá cẩn trọng trong tình yêu, không vội vàng yêu ai đó như kiểu “tình yêu sét đánh”. Tuổi Hợi trước khi quyết định yêu một người nghĩa là đã hiểu rõ bản thân mình thực sự có tình cảm với đối phương và hiểu rõ về con người của đối phương. Nhìn chung, họ cũng có khuynh hướng kết hôn khá muộn so với các tuổi khác.
Nam giới tuổi Hợi thường là những người rất đáng yêu và nhiệt tình. Khi đã yêu ai đó, họ cũng thường yêu hết lòng. Họ cũng là những người rất coi trọng gia đình. Sau khi kết hôn, họ luôn đặt hạnh phúc và lợi ích của gia đình lên hàng đầu để làm động lực phấn đấu trong sự nghiệp. Những người phụ nữ lấy chồng tuổi Hợi đều sẽ được trở thành người vợ, người mẹ vô cùng hạnh phúc.
Vì rất coi trọng gia đình nên với những người đàn ông tuổi Hợi, vợ và con cái của họ là những người chiếm vị trí cao nhất và không thể thay thế được. Người đàn ông tuổi Hợi thì thường không biết bày tỏ tình thương yêu. Họ khá vụng về trong cách biểu đạt tình cảm của mình cho những người thân yêu nhất nhưng lại làm khá tốt với những người ngoài khi cần xã giao. (bói tình duyên)
Nữ giới tuổi Hợi lại là điển hình của những người vợ chịu thương chịu khó. Họ cũng luôn hoàn thành, chăm lo tôt tất cả mọi việc trong gia đình, coi trọng vấn đề giáo dục con cái. Tình yêu thương con cái vô bờ bên của họ biến họ trở thành những người mẹ nhân từ và tuyệt vời nhất. Họ cũng không thích chủ động mà thích được người khác chăm sóc, hỏi han ân cần, nhẹ nhàng. Nếu có một người vợ tuổi Hợi, các ông chồng sẽ gần như không phải lo lắng bất kỳ điều gì về gia đình của mình. Ngưòi tuổi Hợi cũng không cần có một cuộc sống phải thật giàu sang, phú quý. Điều mà họ quan tâm nhất chính là tình cảm giữa vợ chồng, con cái trong gia đình.
Những người vợ tuổi Hợi cũng luôn đối xử ân cần, chu đáo với bạn bè của mình lẫn của chồng và không ngại trả lời những câu hỏi “bất tận” của lũ trẻ. Họ thích chăm lo tốt nhất cho cuộc sống của cả gia đình và coi đó là niềm vui của mình. Khi được ở bên họ, những người khác sẽ luôn cảm thấy vui vẻ, thoải mái. Họ đi đến đâu là nơi đó tràn ngập tiếng cười và không khí vui nhộn, hoạt bát. Sự dịu dàng, nhẹ nhàng của họ còn được thể hiện ngay cả khi họ kêu ca, phàn nàn về một điều gì đó.
Đối tượng kết hôn của người tuổi Hợi
Người tuổi Hợi đôi khi cũng cảm thấy phiền lòng, dẫn đến cãi cọ với người yêu của mình. Họ cũng tương đối đào hoa nhưng điều đó không được thể hiện rõ ràng lắm. Rất nhiều trưòng hợp, có một đối tượng lý tưởng nào đó xuất hiện bên cạnh họ nhưng họ lại bỏ qua mà không nắm bắt lấy cơ hội đó, để rồi khi mọi việc qua đi lại thấy vô cùng hối hận. Họ có thể cãi cọ với người yêu chỉ vì những chuyện rất nhỏ nhặt để rồi sau đó lại thấy rằng mình hoàn toàn không nên làm như vậy.
Xem thêm chi tiết về tình duyên cho người tuổi hợi năm đinh dậu 2017: http://hopdongtinhyeu.vn/article/539/boi-tinh-duyen-cho-nguoi-tuoi-hoi-nam-dinh-dau-2017
@artmaker
You need to Append the mesh after you make it, it shows up when you hit Append. You don’t seem to have appended in your video.
I’ve never had to append a Umesh to get it to show up. It just pops right into the tool list.
|@Aurick
The post two (or so) above this is a vietnamese horoscope, and is either spam or an accident.
I didn’t try the link but it needs deleting.
Also if you read it and dont pass it on you will marry a pig man, he will have multiple chins and slobber on your neck at restaurants.
Beware!
@Brundle fly… I mean… oh god I cant stop laughing!
@Spyndle
You just made me laugh so hard I think I broke something. Theres coffee everywhere.
Oh my god that was funny
Im going to make a Brundefly button that does exactly what it describes.
Ok… hehe…
The UI as I have it is perfect for how I work actually, I usually have my wacom tablet in my lap and use my left hand for that, and the mouse in my right,
I use the keyboard as little as possible, usually just for selections and stuff.
Now that my UI is shrunk back down I can get at what I need almost instantly and the only buttons I ever move things like the Best Render button (I use 2.5D constantly), which I put up next to Active and Total Points, occasionally with other stuff but that’s rare.
I have tried making other UI’s and didn’t like any of them, but one thing I am working on is my own brush palette, its not going well for some reason. Im trying to do that because I use almost none of the stock brushes and am at my wits end with that palette since I cant delete the ones I dont use. Once I do that, if I like it, I will do the Alpha and Texture ones as well.
I tend to laugh (now) when people bitch about the “whole UI” being a nightmare, I find it to be amazingly fast and wish other software companies would smarten the hell up.
I think a lot of how I work is based on muscle memory, and as a result I dislike moving things too much, a great example of that is Render Booleans in the Render Menu is now where External Render was and I keep clicking that instead of External render… I will get used to it, but I keep doing it. That one is unimportant, but the brush thing is important and has to go.
Ripley: “It was in my way”.
Brundlefly… hehehe that was seriously funny!
I think the Brundlefly button should be a combination of every single button in ZBrush being pressed at the same time.
I love waking up to things like that, thank you!
|@Aurick(?)
I missed where you edited that post.
Yes, that’s the window I mean, it crashes and makes the whole screen go white.
HOWEVER, I have figured out how to fix it:
  • FN F3 turns off my network connection.
  • Run ZBrush.
  • Then do FN F3 again to turn the network back on.
With the network OFF that window doesn’t show up at all and thus cant crash or hang or what ever its doing.
YAY!
@Dillster
@Spyndal
Maybe im confused but you cant append something that’s not in the tool palette right?
Isn’t that the problem? Its not showing up there?
@MealeaYing
@Dillster
@Sptndal
Yes, thanks. that is the issue. There is no new mesh tool to append.
A clue maybe:
Pressing ESC to abort after pressing Make Boolean Mesh has no effect. The run time (about 8 sec) and status indicators seem the same either way. Perhaps it is aborting?
Problem with 3D Print Hub:
Resizing does not apply to all subtools, just the subtool selected (‘For All Tools’ is on).
@Mealea
I don’t know if you’re aware of this or not but if you see a spam post, click the small triangle at the bottom left of the post to report it.
@Spyndel Yeah, I was afraid it’s not the Live Boolean Issue but had to confirm.
@artmaker There are 3 things happen when button Make Boolean Mesh is pressed:
  1. Zbrush saves a .csg files in C:\Users\Public\Documents\ZBrushData\ZPluginData\CSGData\-randomID-\ (Users/Shared/ZBrushData/ZPluginData/CSGData/-randomID-/ on OSX) randomID folder is created for each operation and removed afterwards. Generally files are called Subtool1.csg, Subtool2.csg... Graph.csg. Make sure You (ZBRush and spawned process) have permissions to do so.
  2. A binary ZBrush 4R8\ZData\ZPlugs64\csg\csg_boolean.exe (on windows, but I think You would have same name) is called. It is used for generation of the UMesh. Make sure it is properly runs. (I have no idea about process monitoring on OSX).
  3. An output0.csg is generated and loaded by ZBrush
@Zber:
I had no idea! Thanks!
Hi
I’m having a bit problem with the Right-click action that was assigned to the lower button of my grip pen (I’m using the Wacom Intuos Pro M tablet). The Right-click navigation works as usual but something is weird here. If I turn off the Right-click Navigation and Right-click Popup under the Preferences tab, whenever I right-click on the canvas, the pop-up menu shows up?
I just did a clean re-installation for the Wacom latest driver after doing a Full-install of 4R8 on Win7. Any idea I can fix this?
@Zber:
I’m trying to make macros but they dont work, like they dont do anything at all.
Why does this not work?
It’s in the startup folder, has a nice name and all that happy horseshi… ahem… stuff.
//ZBRUSH MACRO - Recorded in ZBrush version 4.8
[IButton,???,“Press to run this macro. Macros can be aborted by pressing the ëescÃ* key.”,
[IShowActions,0]
[IConfig,4.8]
[ISet,Preferences:IColors:Popup Opacity,100]
[IUnPress,Preferences:Interface:Fx16_One OPEN SUBPALETTE]
So what am I doing wrong now? This only does two things, I need one that does like ten things but I figured I would start small.
Do I need to make one macro for every button?
