win 7 pro
top of app: zb 4r4 p2
Able to assign hotkeys to brush presets, zb does not recognized hotkey call.
Action
Open brush pallet press eg. b
Choose brush shortlist eg. m
Hold cntrl. + Alt. choose Move brush
Message hotkey creation successful
Choose a different brush choose numeric (keyboard top) or letter doesn’t matter which, nothing happens
Caps Lock not active.
Try reassign: hotkey already assigned to ui item message.
Loading the hotkey file from the previous version of zbrush works fine. The hotkey file in 4r4 p2 appears to not be writing even after instruction zb to save the newly assigned hotkeys on closing opening the file in wordpad shows no changes.
Cheers guys, great release,
still picking jaw up from floor!
edit
Looks like zb doesnt see the hotkey file in the startup/hotkeys folder. The file has to be manually loaded with each startup. It is the copied previous zb version hotkey file though, although I cant see any difference between the two versions.
edit: For anyone else. Saving a copy of the hotkey file from programfiles(86)/Pixologic/startup/hotkeys to Public/PublicDocuments/Zbrushdata/ZStartup/Hotkeys. Works. Seemed to have kickstarted something because now hotkeys can be made and you are also asked if you want to save when quitting, and the keys work on the next restart.
