damn, cool project. you did a good job turning it into 3d.
-r
awesome project!
Iām sure leonard was really happy about your work!
great job!
Very, very cool
Love the Monster Project idea.
Thx guys!
Small brake from retrogasm:)
First Wip based on Blad Moranās design:After-6-oclock-fairy. Still a long way to go but this is gone be fun.
Check out her original concept:https://www.behance.net/galleā¦/27909831/After-6-oclock-fairy
Awsome project. Awesome Monster. Good job both of you.
hey man i was just wondering as you seems os vell versed in zbrush if you could give me a few pointers as im ultimately stuck!!!
nice progress patrick. i really like her hair.
did you use fibermesh as a base for the curves, or is all done in maya/max etc.?
-r
sheās great! love it
Thx Intervain glad you like her
TheTyrannicalModeler just keep at it
Hey Rasmus, well I did use 3 different types of hair creation.
1 for the buns I used a Torus and converted polyloop to curve to hair. It has history on the curves abd I keep the torus to render in the same material as the hair
2 I export a decimated mesh with uv data to maya and use paintfc to draw curves on it then convert pfx to curves rebuild curves and attach hair to them
3 yup fibermeshes for the eyebrows and some loose strans I used fibermesh exported as curves and attached hair in maya
they all have there advantages and disadvantagesā¦
hope this helps
Patrick I know Iāve mentioned previously elsewhere, but itās a real pleasure to see the process behind this and all the effort thatās gone into it. I also really enjoyed your go monster project!
THX James
Here is an quick photoshop edit on the model I have so far. I am going to call the modelling didnāt catch the character 100% tho. Still to do: Maybe distort the mesh somehow to compare more with the original.
I have to redo the entire hair as it still is on the old head. Different elements need some tweaks on the placement.
I think I am going to sculpt out the jelly around her mouth doesnāt really make sense to have it as a texture.
Add some extra fur here and there. Add some fx like smoke. I think I am gone make the text also in 3d. Check the flakes. Check saturation in post. Still quiet a lot to do but I am getting closer
update still not there yetā¦I will have to speed it up because I feel the need to work on other characters growing :(.
looking really good!
two things that would get you closer to the original (except you did the two points on purpose)
-bring the feet closer together. now her whole weight is on her left leg but in the original concept itās on both legs
-her head needs to be a little bit tilted to her right
keep going youāre almost there!
Great work, very funny!
Thx guys!
Got stuck with the fairy
. 3d characters can be brutal. She doesnāt really like and neither me. Going to let it rest for a whileā¦
So took a break, Marco time! I think I am gone go for more a cinematic approach instead of always those square presentation/turntables. Still a wip tho testing some angles.
Here are the final images of theSix O clock fairy of Blad Moran. Turned out quiet a challege and I do have kinda mixed feelings about the result but that means there is still a lot to learn
As always almost everything is done in Zb except the rendering thatās in vray maya.
Cute!
Thx webhead
new project
based on The little girl with the matchsticks is a short story by Danish poet and author Hans Christian Andersen. First WIP
