Rafslash asked me about fibers and I figured that it would be good to re-post what I wrote down here because fuzzy stuff is good!
Its surprisingly easy too use which is nice.
- Start with any object. (dont forget that accursed EDIT MODE)
- Go into the Materiel Pallet on the left and set your object to Fibers.
- If it does not change color see more info below.
- In the Render Menu (at the top) open Render Properties and turn on Fibers and AF.
- Now render your object, it should be fuzzy!
Ok,
here is the “more info below” bit, if your object does not change how
it looks or after rendering does not look fuzzy do the select Fibers thing again and go to the Color Menu (at the top) and hit Fill Object.
Note >>>—> If you are in R2 and using objects from LightBox a lot of them have color and materiel assigned already, Fill Object is your
friend in this case.
There are a bunch of fiber adjustments in the Modifiers pallet under the Materiel Menu at the top, Look at the top of the pallet and you
will see S1 and S2 select S2 and fiddle with the settings in there, they are great fun but try them one or two at a time as they do
surprisingly large changes.
You can also paint fuzz where you want it which is very very very amusing (and sort of tricky at times for some reason).
To do that:
- Set your objects materiel like you did above but to something other then Fibers (try something light for the moment).
- Turn on Colorize in the PolyPaint Pallet on the right.
- At the top select MRGB (this sets materiel and color).
- Turn off Zadd. (this is optional, but if it is on you will be sculpting AND painting at the same time).
- Try drawing on your object.
- Mess with the color! Its great fun!
If
it doesn't work change brushes and make sure #3 and #4 are still as they should be, some brushes dont paint well or even at all.
No mater what you do with fibers the Snake Hook Brush is awesome both in 3D and in 2.5D,
change its color and as it drags out it will fade from the color you
are grabbing with it to the one you have selected, its a total blast!
Thank you Rafslash!!!
Cheers!
Mealea
I almost forgot, this is a VERY IMPORTANT THREAD:
http://www.zbrushcentral.com/showthread.php?95538-Fiber-Thread-—-FIBRE-CLUB
Thats where the fuzzy stuff lives!
