ok, now i see what you mean, yes, right… will not change though, it is one huge mesh, and hardly editable anymore… i will recall however next time i sculpt knees.
Hi Kokoro, Quite lovely! I knew immediately who it belonged to from the thumbnail!
All the best, David
I can’t believe it’s not editable.
Enlarge the knees. Just a bit. OK, not that simple.
Is it a single mesh? No it isn’t. Right?
thanks david, yes michalis now it is a single mesh, 25 million polygons, i needed do that for the vertexpaint, and for the sss to render correct… you know, if they are differnet objects, the sss is wrong on some of them,it showed to badly… the view port is slow with such a heavy mesh…
Doris, yeah, the SSS,
You know what? I still find SSS cycles behavior a little weird in some areas. Like they are still separated meshes. I’m pretty sure you noticed it.
Very beautiful.
yes, i did, but it is much better than before joining the meshes into one … we both know, cycles even though wonderful, is still in its babyshoes…
solidsnakes, thank you!
Your work is a miracle!
small_orange_diamond
But … Really - this lady should add volume to the hips.
lexxx, again i have to ask, you mean for your taste, or for anatomically correct , in this case, ithink she is fine though, thanks!
Du hast einen sehr schönen Stil, wie ein digitaler Bildhauer. Das macht es sehr “erfühlbar”, dadurch wirkt es echt.
Das gefällt mir sehr gut. Es gibt in Görlitz einen Brunnen, welcher im Volksmund “Muschelminna” genannt wird.
Diese Art von Skulpturen haben mich immer fasziniert.
Mach weiter so!
Ciao,
TM
ich mache ja auch bildhauerarbeiten (hobby nur), holz, stein, ton, siehe homepage, das übersetze ich “einfach” ins digitale. werde mal den brunnen googlen! danke tribunmaximus
a speedy sculpt from tonight , jakob:
Beautiful job done on these last two pieces Kokoro
…Your work just keeps getting stronger…Great to see that happening…
:)Glenn
thank you glenn! glad to hear that …yes i too feel i collected some experience with portraits, that now lets me create what i want express.
Great work on this one Doris!
I very much like what you did on the hair, BTW.
thanks michalis! yes, the hair, simplification and curves!
Hi Kokoro, this iast is very powerful! I love it!
All the best, David
thank you david
for today, something different, i got loopilitis, maybe??? technocat cheetah, displacement map is one michalis shared, thanks michalis!
full resolution image to enjoy all the details is here, as i cannot upload 1mb files…
Du weißt schon, das es keine Heilung bei der ZLoop-Krankheit gibt?
Im Ernst, das sieht sehr cool aus!
Ciao,
TM
