Hi there.
Did anyone here ever manage to call a function from a C# .net assembly from ZScript using [FileExecute, “AssemblyName.dll”, “FunctionName”]?
If so, which attributes did you use to make the C# method visible?
Do I have to (or can I) include the name of the class before the function name? Will “ClassName.FunctionName” work?
Does the assembly have to be marked (registered) for COM interop?
Tried most of these options, but I’m probably missing something. So far I´ve been unable to get even a Hello World message to pop up from my assembly.
Glad you solved that. I was hunting around and found this, which might be useful:
