policarpo wrote:
“Hey gang, I was wondering if any of you zBrush owners might be willing to part with an object with a displacement map like Pixolator did so we could run some more tests using our rendering package of choice.”
- Sounds like a good idea!
- Here is my object!
20040502_displacement_test.zip
Renderings of model:
In Zbrush - it is just a modified / detailed version of object i made earlier:
Map from zbrush:
End result in 3dsmax:
As you can see, i didn’t use GUV tile mapping, UVs are done in 3dsmax - no smoothing either!
I rendered the map in 4096pix, but had to scale down to 2048pix for download size - sorry! I can’t host huge files
Map should still be in one channel / 16bit mode…
I didn’t do any retouching except scaling, so there might be some problem areas
I hope there is no banding, i couldn’t get more subdivision with my system (1.8m now), i tried all possible zbrush memory settings, but no luck
- I managed to get mesh divided to 7.8m polys, but zbrush crashed when i tried to render displacement map… -
Please read the readme file in ZIP - nothing special in it, just don’t abuse poor 3d guy
Readme also has information how to setup the model for rendering in 3dsmax, zbrush displacement values are also provided!
Have fun!
P.S.
Tip: You get also my base mesh for testing, just reconstruct it from cage mesh!
-S-S
