Zbrush Material "baking"
Hi, is it possible to export the Material (Metall) to another application and keep the material? Thanks!
Yo! You can try this, http://www.youtube.com/watch?v=fpZutuxx09M
Easier:
http://www.zbrushcentral.com/showthread.php?170886-MatCap-Baker!-unofficial-Information-Installation
It should be noted that either method wont give you the same material in the end. You’ll wind up with a static texture, which 99% of the time will lose its luster. If you are looking to imitate the look that you get in zbrush, you’ll need to
  1. Apply the matcap to a sphere
  2. Frame the sphere in the document (a square resolution might help)
  3. Export the document and use the result as a texture on the equivilant litsphere/grayball shader in the other program
