Hello All!
It was a blast to test all the new, outstanding features of this new release!
it’s loaded!!!
My favorites additions are Dynamesh (I’m tempted to change my user to dynamesher ha!): total freedom from our dreaded topologies, create at the speed of your Vision! The new Clay Polish function helps in cleaning up sketches on the fly removing all the useless small imperfections. The Curve Brushes are a bit too much to explain in writings… you have to try them to believe! Render Filters gives an extra dimension to the images generated within Zbrush without any Photoshop post processing. Clip curve allows to separate sections of the model as independent pieces of geo!
anyway here are my humble attempts while trying to tame this beast:
This one had been all created starting with a cube and a curve for the deco’ part, then dynamesh maddness. All the teeth and the rest had been clipped out from the main chunk:
Turntable:
[video=vimeo;29151937]http://vimeo.com/29151937[/video]
I have making of videos as well I’m sure the headquarters are going to link them here
right?
and here a very early WIP on something else that will pop up here in a little while longer…
thank you all!!
… if the situation changes I’ll post them
