Zbrush 4 Retopo Problems (answered)
Hello,
I have been trying to retopo a character using the retopology tool in Zbrush 4, but I can see my retopo mesh underneath my character. As a result, when I add new points, they sometimes connect to the mesh on the other side.
I have tried to hide the retopology on the other side of the mesh (ctrl-shift and drag over selection), but it crashes Zbrush 4.
I am pleased that Pixologic improved the retopo tool (inconsistent snapping to points and missing faces), but it seems to now have a few new problems.
Are there any work a rounds or fixes for these retopo problems?
Thanks,
Yes, I am doing that too and I was thinking that if I could adjust the opacity of the subtool being retopologized, the new points might not go to other points on the other side so easily.
I looked in preferences to see if I could adjust the opacity but I couldn’t find anything. Now I see lines mostly and it gets difficult to stay organized.
Can we adjust the opacity of the subtool being retopologized?
got the same problem. Still no fix in sight…
http://www.zbrushcentral.com/showthread.php?t=92166
bye e
yikes! This takes forever to work like this. A really large portion of my job involves retopologizing, this may be a deal breaker for Z4 for me until this is fixed unfortunately. I can retopologize with a quickness in the past versions. :slight_smile:
Hello,
The crashing only seems to occur on dense meshes (3 or 4 divisions). If you retopo a simple sphere and try to hide a portion of the retopologized mesh, it hides the retopo work and does not crash.
for those who havn´t seen, the problem has been solved:
bye e
Thanks elektro,
It will be helpfull and give us another way to draw a new topology.
But there is always a bug (in my opinion) when you want to use the traditional method
>> rigging -> Select mesh … Topology/Edit Topology
Maybe a new patch soon ?
Cool! Thanks for the link.
Thank you very much elektro for the link! It looks like this method offers other benefits to retopologizing in addition to the fix. Thanks.
Your welcome :smiley:
The credit goes to grfx.
bye e
I fixed this!
Go into Preferences/Draw and change the Front Opacity Slider value to 1. Makes it work like it used to.
Extra Dimensional- YES! That is a quicker way for me, thanks for figuring it out.
Yes, it’s good
Thanks Extra Dimensional
Thanks Extra Dimensional! I did not know you could adjust the opacity. Cool!
Extra Dimensional-thanks god ! you saved me ! I think your approach should be the best solution,thank you very much!!
but I can still select the point on the other side. thats annoying.
Try these settings in Preferences > Draw submenu.
Front Opacity 0.95
Back Opacity 0.01
Use 3d-coat
it still snaps but it doesnt draw the line through the mesh! ok. thx
hello everyone, i have a problem when retoping my model. on the picture you can see i can’t connect those two vertices (zspheres), but when i move them much closer to each other, the edge is creating… and it is over all the mesh, like i have a limit in distance between 2 vertices… like 10 px or so, i changed the settings for radius in preferences->zsphere, but nothing actually helped. any ideas? thanks…
so idea is that i can retop like very tiny wireframe, but when i want less quads in my low poly (bigger wireframe), i can’t do that.
