Hit me… or rather my inbox
I’ve watched all the vids, read the features and saw all the beta stuff in the forums. I’m ready!
Anyone else having trouble loading spotlight.
When I click the spotlight button under the texture tab it appears to search for a spotlight.zsl file but no such file exists on my system.
No errors during install or activation - selected full install and defaults.
Running on Windows 7 Any help appreciated.
You can save and load spotlight files, that’ what it’s looking for. To start lightbox, go into texture menu, select a texture and hit the send to spotlight button. This will bring up spotlight.
Hi, this bug also occurs on windows though.
Thanks for ZB4.
Some nice new features, but as always in ZB, not really easy to handle.
Shadowbox could be a really nice tool with the new brushes, but some clipping brushes behaves strange (cut the whole model instead of the edge when you use it on the left side of the model ) and some other requires artistic keyboard actions to use them. (for instance the clipcurve brush: strg + shift + alt + LMB-Pen action at the same time
I wonder if I will use these gimmicks frequently as there are enough other apps that produces same results with more ease.
GoZ is a real improvement and seems to work with C4d, so thanks for that.
But it also seems that it is unfortunately not much more than a quicker variation of the the old obj-import feature as it doesn’t support changes in the topology when the mesh is on more than one sub-d-level.
Pixologic!
It seems that you have done again a great job. But those activation problems, that’s really annoying!!!
[ATT=]license.JPG[/ATT]
I had the same problem. If you keep trying you’ll eventually get it. Too many people all at once that’s all.
Just click on the button periodically until you get it.
After working with it a while, in some ways I feel like ZB 4 is really the very first true version of Zbrush. It actually finally lives up to its promise of unhinged free form creation, where I can really make anything I envision, and it seems to benefit from a good deal of polish over the last version.
Thank you for this tool, which is going to change the way I work yet again.
Well said.
Hello,
I know this is not Pixologic’s fault. Cleverbridge has not catered for the demand of all the eager ZBrush 4 upgraders.
I got an error instead of an activation code.
<link rel="“File-List”" href=“file:///C:%5CUsers%5CPaul%5CAppData%5CLocal%5CTemp%5Cmsohtmlclip1%5C01%5Cclip_filelist.xml”><link rel="“themeData”" href=“file:///C:%5CUsers%5CPaul%5CAppData%5CLocal%5CTemp%5Cmsohtmlclip1%5C01%5Cclip_themedata.thmx”><link rel="“colorSchemeMapping”" href=“file:///C:%5CUsers%5CPaul%5CAppData%5CLocal%5CTemp%5Cmsohtmlclip1%5C01%5Cclip_colorschememapping.xml”><!–[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:TrackMoves/> <w:TrackFormatting/> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:DoNotPromoteQF/> <w:LidThemeOther>EN-AU</w:LidThemeOther> <w:LidThemeAsian>X-NONE</w:LidThemeAsian> <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> <w:SplitPgBreakAndParaMark/> <w:DontVertAlignCellWithSp/> <w:DontBreakConstrainedForcedTables/> <w:DontVertAlignInTxbx/> <w:Word11KerningPairs/> <w:CachedColBalance/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> <m:mathPr> <m:mathFont m:val=“Cambria Math”/> <m:brkBin m:val=“before”/> <m:brkBinSub m:val="–"/> <m:smallFrac m:val=“off”/> <m:dispDef/> <m:lMargin m:val=“0”/> <m:rMargin m:val=“0”/> <m:defJc m:val=“centerGroup”/> <m:wrapIndent m:val=“1440”/> <m:intLim m:val=“subSup”/> <m:naryLim m:val=“undOvr”/> </m:mathPr></w:WordDocument> </xml><![endif]–><!–[if gte mso 9]><xml> <w:LatentStyles DefLockedState=“false” DefUnhideWhenUsed=“true” DefSemiHidden=“true” DefQFormat=“false” DefPriority=“99” LatentStyleCount=“267”> <w:LsdException Locked=“false” Priority=“0” SemiHidden=“false” UnhideWhenUsed=“false” QFormat=“true” Name=“Normal”/> <w:LsdException Locked=“false” Priority=“9” SemiHidden=“false” UnhideWhenUsed=“false” QFormat=“true” Name=“heading 1”/> <w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 2”/> <w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 3”/> <w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 4”/> <w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 5”/> <w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 6”/> <w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 7”/> <w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 8”/> <w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 9”/> <w:LsdException Locked=“false” Priority=“39” Name=“toc 1”/> <w:LsdException Locked=“false” Priority=“39” Name=“toc 2”/> <w:LsdException Locked=“false” Priority=“39” Name=“toc 3”/> <w:LsdException Locked=“false” Priority=“39” Name=“toc 4”/> <w:LsdException Locked=“false” Priority=“39” Name=“toc 5”/> <w:LsdException Locked=“false” Priority=“39” Name=“toc 6”/> <w:LsdException Locked=“false” Priority=“39” Name=“toc 7”/> <w:LsdException Locked=“false” Priority=“39” Name=“toc 8”/> <w:LsdException Locked=“false” Priority=“39” Name=“toc 9”/> <w:LsdException Locked=“false” Priority=“35” QFormat=“true” Name=“caption”/> <w:LsdException Locked=“false” Priority=“10” SemiHidden=“false” UnhideWhenUsed=“false” QFormat=“true” Name=“Title”/> <w:LsdException Locked=“false” Priority=“1” Name=“Default Paragraph Font”/> <w:LsdException Locked=“false” Priority=“11” SemiHidden=“false” UnhideWhenUsed=“false” QFormat=“true” Name=“Subtitle”/> <w:LsdException Locked=“false” Priority=“22” SemiHidden=“false” UnhideWhenUsed=“false” QFormat=“true” Name=“Strong”/> <w:LsdException Locked=“false” Priority=“20” SemiHidden=“false” UnhideWhenUsed=“false” QFormat=“true” Name=“Emphasis”/> <w:LsdException Locked=“false” Priority=“59” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Table Grid”/> <w:LsdException Locked=“false” UnhideWhenUsed=“false” Name=“Placeholder Text”/> <w:LsdException Locked=“false” Priority=“1” SemiHidden=“false” UnhideWhenUsed=“false” QFormat=“true” Name=“No Spacing”/> <w:LsdException Locked=“false” Priority=“60” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light Shading”/> <w:LsdException Locked=“false” Priority=“61” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light List”/> <w:LsdException Locked=“false” Priority=“62” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light Grid”/> <w:LsdException Locked=“false” Priority=“63” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Shading 1”/> <w:LsdException Locked=“false” Priority=“64” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Shading 2”/> <w:LsdException Locked=“false” Priority=“65” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium List 1”/> <w:LsdException Locked=“false” Priority=“66” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium List 2”/> <w:LsdException Locked=“false” Priority=“67” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 1”/> <w:LsdException Locked=“false” Priority=“68” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 2”/> <w:LsdException Locked=“false” Priority=“69” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 3”/> <w:LsdException Locked=“false” Priority=“70” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Dark List”/> <w:LsdException Locked=“false” Priority=“71” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful Shading”/> <w:LsdException Locked=“false” Priority=“72” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful List”/> <w:LsdException Locked=“false” Priority=“73” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful Grid”/> <w:LsdException Locked=“false” Priority=“60” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light Shading Accent 1”/> <w:LsdException Locked=“false” Priority=“61” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light List Accent 1”/> <w:LsdException Locked=“false” Priority=“62” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light Grid Accent 1”/> <w:LsdException Locked=“false” Priority=“63” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 1”/> <w:LsdException Locked=“false” Priority=“64” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 1”/> <w:LsdException Locked=“false” Priority=“65” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium List 1 Accent 1”/> <w:LsdException Locked=“false” UnhideWhenUsed=“false” Name=“Revision”/> <w:LsdException Locked=“false” Priority=“34” SemiHidden=“false” UnhideWhenUsed=“false” QFormat=“true” Name=“List Paragraph”/> <w:LsdException Locked=“false” Priority=“29” SemiHidden=“false” UnhideWhenUsed=“false” QFormat=“true” Name=“Quote”/> <w:LsdException Locked=“false” Priority=“30” SemiHidden=“false” UnhideWhenUsed=“false” QFormat=“true” Name=“Intense Quote”/> <w:LsdException Locked=“false” Priority=“66” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium List 2 Accent 1”/> <w:LsdException Locked=“false” Priority=“67” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 1”/> <w:LsdException Locked=“false” Priority=“68” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 1”/> <w:LsdException Locked=“false” Priority=“69” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 1”/> <w:LsdException Locked=“false” Priority=“70” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Dark List Accent 1”/> <w:LsdException Locked=“false” Priority=“71” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful Shading Accent 1”/> <w:LsdException Locked=“false” Priority=“72” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful List Accent 1”/> <w:LsdException Locked=“false” Priority=“73” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful Grid Accent 1”/> <w:LsdException Locked=“false” Priority=“60” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light Shading Accent 2”/> <w:LsdException Locked=“false” Priority=“61” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light List Accent 2”/> <w:LsdException Locked=“false” Priority=“62” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light Grid Accent 2”/> <w:LsdException Locked=“false” Priority=“63” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 2”/> <w:LsdException Locked=“false” Priority=“64” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 2”/> <w:LsdException Locked=“false” Priority=“65” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium List 1 Accent 2”/> <w:LsdException Locked=“false” Priority=“66” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium List 2 Accent 2”/> <w:LsdException Locked=“false” Priority=“67” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 2”/> <w:LsdException Locked=“false” Priority=“68” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 2”/> <w:LsdException Locked=“false” Priority=“69” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 2”/> <w:LsdException Locked=“false” Priority=“70” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Dark List Accent 2”/> <w:LsdException Locked=“false” Priority=“71” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful Shading Accent 2”/> <w:LsdException Locked=“false” Priority=“72” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful List Accent 2”/> <w:LsdException Locked=“false” Priority=“73” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful Grid Accent 2”/> <w:LsdException Locked=“false” Priority=“60” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light Shading Accent 3”/> <w:LsdException Locked=“false” Priority=“61” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light List Accent 3”/> <w:LsdException Locked=“false” Priority=“62” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light Grid Accent 3”/> <w:LsdException Locked=“false” Priority=“63” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 3”/> <w:LsdException Locked=“false” Priority=“64” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 3”/> <w:LsdException Locked=“false” Priority=“65” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium List 1 Accent 3”/> <w:LsdException Locked=“false” Priority=“66” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium List 2 Accent 3”/> <w:LsdException Locked=“false” Priority=“67” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 3”/> <w:LsdException Locked=“false” Priority=“68” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 3”/> <w:LsdException Locked=“false” Priority=“69” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 3”/> <w:LsdException Locked=“false” Priority=“70” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Dark List Accent 3”/> <w:LsdException Locked=“false” Priority=“71” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful Shading Accent 3”/> <w:LsdException Locked=“false” Priority=“72” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful List Accent 3”/> <w:LsdException Locked=“false” Priority=“73” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful Grid Accent 3”/> <w:LsdException Locked=“false” Priority=“60” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light Shading Accent 4”/> <w:LsdException Locked=“false” Priority=“61” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light List Accent 4”/> <w:LsdException Locked=“false” Priority=“62” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light Grid Accent 4”/> <w:LsdException Locked=“false” Priority=“63” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 4”/> <w:LsdException Locked=“false” Priority=“64” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 4”/> <w:LsdException Locked=“false” Priority=“65” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium List 1 Accent 4”/> <w:LsdException Locked=“false” Priority=“66” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium List 2 Accent 4”/> <w:LsdException Locked=“false” Priority=“67” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 4”/> <w:LsdException Locked=“false” Priority=“68” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 4”/> <w:LsdException Locked=“false” Priority=“69” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 4”/> <w:LsdException Locked=“false” Priority=“70” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Dark List Accent 4”/> <w:LsdException Locked=“false” Priority=“71” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful Shading Accent 4”/> <w:LsdException Locked=“false” Priority=“72” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful List Accent 4”/> <w:LsdException Locked=“false” Priority=“73” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful Grid Accent 4”/> <w:LsdException Locked=“false” Priority=“60” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light Shading Accent 5”/> <w:LsdException Locked=“false” Priority=“61” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light List Accent 5”/> <w:LsdException Locked=“false” Priority=“62” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light Grid Accent 5”/> <w:LsdException Locked=“false” Priority=“63” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 5”/> <w:LsdException Locked=“false” Priority=“64” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 5”/> <w:LsdException Locked=“false” Priority=“65” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium List 1 Accent 5”/> <w:LsdException Locked=“false” Priority=“66” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium List 2 Accent 5”/> <w:LsdException Locked=“false” Priority=“67” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 5”/> <w:LsdException Locked=“false” Priority=“68” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 5”/> <w:LsdException Locked=“false” Priority=“69” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 5”/> <w:LsdException Locked=“false” Priority=“70” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Dark List Accent 5”/> <w:LsdException Locked=“false” Priority=“71” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful Shading Accent 5”/> <w:LsdException Locked=“false” Priority=“72” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful List Accent 5”/> <w:LsdException Locked=“false” Priority=“73” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful Grid Accent 5”/> <w:LsdException Locked=“false” Priority=“60” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light Shading Accent 6”/> <w:LsdException Locked=“false” Priority=“61” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light List Accent 6”/> <w:LsdException Locked=“false” Priority=“62” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Light Grid Accent 6”/> <w:LsdException Locked=“false” Priority=“63” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 6”/> <w:LsdException Locked=“false” Priority=“64” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 6”/> <w:LsdException Locked=“false” Priority=“65” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium List 1 Accent 6”/> <w:LsdException Locked=“false” Priority=“66” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium List 2 Accent 6”/> <w:LsdException Locked=“false” Priority=“67” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 6”/> <w:LsdException Locked=“false” Priority=“68” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 6”/> <w:LsdException Locked=“false” Priority=“69” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 6”/> <w:LsdException Locked=“false” Priority=“70” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Dark List Accent 6”/> <w:LsdException Locked=“false” Priority=“71” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful Shading Accent 6”/> <w:LsdException Locked=“false” Priority=“72” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful List Accent 6”/> <w:LsdException Locked=“false” Priority=“73” SemiHidden=“false” UnhideWhenUsed=“false” Name=“Colorful Grid Accent 6”/> <w:LsdException Locked=“false” Priority=“19” SemiHidden=“false” UnhideWhenUsed=“false” QFormat=“true” Name=“Subtle Emphasis”/> <w:LsdException Locked=“false” Priority=“21” SemiHidden=“false” UnhideWhenUsed=“false” QFormat=“true” Name=“Intense Emphasis”/> <w:LsdException Locked=“false” Priority=“31” SemiHidden=“false” UnhideWhenUsed=“false” QFormat=“true” Name=“Subtle Reference”/> <w:LsdException Locked=“false” Priority=“32” SemiHidden=“false” UnhideWhenUsed=“false” QFormat=“true” Name=“Intense Reference”/> <w:LsdException Locked=“false” Priority=“33” SemiHidden=“false” UnhideWhenUsed=“false” QFormat=“true” Name=“Book Title”/> <w:LsdException Locked=“false” Priority=“37” Name=“Bibliography”/> <w:LsdException Locked=“false” Priority=“39” QFormat=“true” Name=“TOC Heading”/> </w:LatentStyles> </xml><![endif]–><style> <!-- /* Font Definitions / @font-face {font-family:“Cambria Math”; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:1; mso-generic-font-family:roman; mso-font-format:other; mso-font-pitch:variable; mso-font-signature:0 0 0 0 0 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-520092929 1073786111 9 0 415 0;} @font-face {font-family:Tahoma; panose-1:2 11 6 4 3 5 4 4 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-520081665 -1073717157 41 0 66047 0;} / Style Definitions / p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; mso-margin-top-alt:auto; margin-right:0cm; mso-margin-bottom-alt:auto; margin-left:0cm; mso-pagination:widow-orphan; font-size:12.0pt; font-family:“Times New Roman”,“serif”; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin;} a:link, span.MsoHyperlink {mso-style-priority:99; color:blue; text-decoration:underline; text-underline:single;} a:visited, span.MsoHyperlinkFollowed {mso-style-noshow:yes; mso-style-priority:99; color:purple; mso-themecolor:followedhyperlink; text-decoration:underline; text-underline:single;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; font-size:10.0pt; mso-ansi-font-size:10.0pt; mso-bidi-font-size:10.0pt;} @page WordSection1 {size:612.0pt 792.0pt; margin:72.0pt 72.0pt 72.0pt 72.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.WordSection1 {page:WordSection1;} --> </style><!–[if gte mso 10]> <style> / Style Definitions */ table.MsoNormalTable {mso-style-name:“Table Normal”; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:“Calibri”,“sans-serif”; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:“Times New Roman”; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:“Times New Roman”; mso-bidi-theme-font:minor-bidi;} </style> <![endif]–>Warning<!–//–>: mysql_connect() [function.mysql-connect<!–//–>]: Can’t create UNIX socket (12) in /home/regadmin/public_html/xXCB/config/settings.php<!–//–> on line 13<!–//–>
Unable to connect to database server: Can’t create UNIX socket (12)
Pixologic should have a service agreement with them to ensure mickey mouse server management is not used in their delivery systems. It is irresponsible for Cleverbridge not to ensure they can cope with the expected traffic of how many upgrades. It looks like Cleverbridge is not clever at all.
I hope Cleverbridge will have to pay penalty costs to Pixologic for their negligence.
I have emailed Cleverbridge customer service to fix this.
Sorry to be so disgrunted. I love ZBrush and really looking forward to trying version 4.
Regards
Luther50 - Paul
This is why i don’t play the lottery…
I am always the last in line!
Still waiting patiently…
Can’t wait to play with Z4…
I’m with ya in the back of the line!
I keep checking my Spam…
Actually, there is already a line behind you guys.
Some of us got wrong platform and have to wait to next Monday before that can be sorted out!
Ouch…
I got my upgrade for Mac yesterday but I also own a PC license. Still waiting on that one!
I feel you guys I have no expectation of receiving my z4 until next week sometime. that way it will be a pleasant surprise if it comes earlier.
thats usually my luck.
but no drama I’m still working with 3… wishing every moment
t
There may be hope for me yet then, as I received Mac licenses today but no PC ones (my current platform) . . .
Not too worried though . . . never missed an upgrade yet in 7 years–the gang at Pixologic always take care of me (eventually!)
-K
I’m witcha. The release looks like another stroke of genious from Pixo. But I guess I’m waiting. I feel sorry for those who had registered the wrong platform.
