***** ZBrush 4.0 Unleashed!
Download ground down to 13 kb/sec. Anyone else facing this? At this rate, the download should be finished by the 24th. :wink:
Negative, still waiting
Please see here for instructions regarding installing MME: http://www.zbrushcentral.com/showthread.php?t=91688
Firstly, I’m on a mac, but I copied the files that were ‘inside’ the unzipped folder to: ZStartup/ZPlugs folder
 and somethings came to life but it seems like PaintStop has interface issues
 anyone know a fix for ZB4 plugs please chime in.
Thanks.
Still waiting but I would be surprised if I got it this week. Not my luck. Last time I needed to email support a week later and then they sent it to my right address. No big deal, just glad this puppy came out on time. So many exciting new features.
Not yet
Thank you so much Pixologic!! :smiley: :smiley: :smiley:
I read in another post that there will be no backwards compatibility
Here’s the ZScript Note when I try to get PaintStop up:
ZScript Note: Interface item could not be found.
Texture: TurnOnLightbox
in
[IGet, Texture: TurnOnLightbox]
any suggestions on what’s going wrong?
Thanks.
Hej kaithomas! I was thinking exactly the same, do I really dare to click the one time link :confused: But I did and it worked!!! :smiley:
Downloaded here !!
It works fine for me .:+1:
Now it’s time to play :sunglasses:
Is there a new way to customize and move buttons from how it was before? I went to preferences, custom ui, enable customize, and held down the button and dragged like the last version and nothing will move.
:confused: Figures. In the past my email has shown up at the end. This time it shows up fast and I don’t have time to even download it till Friday and then I have to work all weekend on a publication due by Monday.
I’m really enjoying ZB4 but I do have some questions:
  1. How do I search the web via lightbox. I see the WWW tab but when I put anything in the search box and click search nothing happens.
  2. I have a bunch of my own Alpha and Ztool folders that I nest links to in their respective folders inside the zbrush folder, so that I can quickly jump around my drives via lightbox. The problem is that I can’t see any of these folders inside lightbox. Only images. This was working previously with 3.5r3 on PC.
  3. How do I paint on my mesh when I have the spotlight tools up? I’m sort of confused at this functionality. Can I use the rotated image as a stencil to pain over my object? I can’t seem to get it to work and I can’t find anything about it in the manuals.
my most underrated new feature/fix: If I am not completely mistaken then the odd perspective view has been fixed. just loaded a character I did and the appended the dog, move it far apart and it did not seem to distort/shrink the perspective. that means you can really set up and render larger scenes now.finally the viewport feel like a proper “room”.
Got my , e-mail, downloaded and installed in amazingly and then this is what I got as a serial number. Waiting for another e-mail now
sigh :cry:
Warning: mysql_connect() [function.mysql-connect]: Can’t create UNIX socket (12) in /home/regadmin/public_html/xXCB/config/settings.php on line 13
Unable to connect to database server: Can’t create UNIX socket (12)
Is it a little early for ideas for a point release? I am enjoying ZB4 with the polypaint layers, but that is pretty much it
 :slight_smile: I am now thinking of maybe layer groups (allowing the groups to have materials set and blended
 i am looking for the blending modes but maybe i am missing something
Well, play on :slight_smile:
Just got mine and everything went very smoothly and without a hitch. Downloading, activating all went well.
@badassembly
as to you 3rd question
once you have your image positioned, press z on your keyboard to paint then press z again to get the spotlight widget back. Oh! and make sure RGB is on at the top.
Did you hold Ctrl while you dragged the items to their new locations? That should do the trick.
Oh goodie! They’re still sending them :wink:
