AHA! There it is!
Man it’s gorgeous! I’m so proud of you Fabrizio! I had the privilege of running his maps through the ZbornToy and it’s been such a blast. For almost a year now I’ve been testing it only with my own stuff and never got totally jaded (except renderingtimes). By now I can’t handle anything that takes longer than 30sec. I’ve noticed that that’s the maximum I can bare…hahahaha.
But Fab did these brutal details and beautiful color choices. When I ran it through after only a few minutes it looked like a perfect gem stone.
Anyway, yes, it’s finally done and I will make a more appropriate post for the announcement, but I havn’t slept in 26 hours now and wonder if I write coherendly right now?! …AH, done, yes, not only the ZbornToy, but also the website is done and everything is in place to finally give it to you!
www.taronites.com
That brings you to the starting page of this new branding. It’s Taronite as in Parasite as in little thing that goes into your system and changes the way it used to run. Hehehehe… ZbornToy is the first and most complex one, but there are more to come, quite a few more! This one is supposed to get you into a new mindset, so, when it comes to compositing, animation and design!
The website is rather wacky…lots of stuff that you need to explore! The Gallery will certainly be the highlight for you, because not only does it show a whole bunch of pretty pictures, it also explains a lot by showing the used elements as well as the final renders!
To view those, you’ll see a little icon in the upper left corner of the preview frame. Loading might delay the response a little, but if you click on it, you will go through a set of images behind the front one. Some of them even have quicktimes. Once you see what you like, just click on the image and it will appear in the large frame.
Back to Fab for the finale of this way too big post: BRAVO, BRAVO, BRAVO!
Taron
