Trial license? What trial license?
Hello. I performed a couple of searches but this topic didn’t turn up.
I downloaded the trial version of Zbrush 3.1 today. The first time I used it the ‘enter serial number’ box popped up. I obviously haven’t purchased anything to recieve a serial number, but I noticed the ‘activate later’ option gave 30 day’s grace, so I figured that was the proper option for the trial and clicked it.
My first session lasted a couple of seconds, when I decided I’d better read a few instructions first. Now, a couple of hours later, when I try to start Zbrush I’m informed my license file is faulty, and it won’t start unless I contact Pixologic and give them my serial number…
This indicates that something has somehow corrupted the installation. In most cases this is caused by a virus. It can also be caused by changing the system clock.
After you’ve made sure the clock is correct and no viruses are present, please browse to the ZBrush folder and delete the file config called ZBrush3.ini. Next, go to the Windows Control Panel. Under the Remove Programs category, locate ZBrush and select it. You should see an option appear above the list to repair or modify. (This varies depending on your version of Windows.) This will run the ZBrush installer again, and you’ll have the choice to repair the installation.
When done, start ZBrush. It will tell you that a problem has been detected with the license and ask if you’d like to recover. It will then give you a request code. Reply to this post with that code so that we can create a recovery code for you and get ZBrush back up and running.
Thanks for the help, Aurick. Sorry, though - I got turned around for a week or so and only remembered about this now. I guess it’s a bit too late to do anything about it… :o
Aurick can you please reply to this thread with a recovery code for me. I downloaded the 30 day trial and i am very anxious to try it but i have been having trouble for some time now trying to get a Recovery Code.
authorization request code 045E-57B8-A29C-65FE
as for replying to this thread can you possibly email it to me as well. I have sent several emails to support and have received no feedback.
[email protected]
[email protected]
Sending an email to support is no longer possible. You need to submit a ticket at http://support.pixologic.com
Here is a recovery code for you: 2B4E-5792-BFCB-9AA8
I’m having the same problem as glynch
this is my code 1C57-2B9C-A664-D45A
Here’s your recovery code: B45F-4304-80AE-CF4A
Hi Aurick, same problem here too.
31CD-3AD9-3C7A-7480
Thanks
Tom
Here is your recovery code: 5FC3-F59A-95AD-A007
Hi Aurick, i have the same problem.
my code is C680-4003-DC25-9BBB
Thanks
7416-2FC4-6EBA-F58C
Hey aur, same problem here
Code: FA11-DA46-613F-73B0
cheers
2355-C78E-F508-FFB7
DEEC-B449-D8FC-C9E9
Sorry same problem here
thankyou
And your recovery code: 6887-D5B5-0C2D-DB23
Hey, sorry same problem.
here’s my request code
A0D2-3E19-616F-54F0
Thank you!
And for you: C1E6-027D-4D93-98FA
I hate to ask too, but yeah, same problem as the rest.
DFFC-5463-ED90-4428
Thank you in advance
Here you go, SpookyDoom: 7817-E33B-D08B-C790
Same problem on this end.
Thank you.
42EF-0C4D-14EB-BAE1
