The plugin seems like it’s no longer available at that link. Is there a way we can download it elsewhere? Thanks.
@Sedghammer, @blackspider: With the release of ZBrush 4R8 all my plugins need to be updated to function correctly. I am currently going through and slowly updating them to work with 4R8 hoping to have them all completed soon
The 4R7 versions of the plugins can be found here: https://gumroad.com/l/ZUjcb
-Joseph
Joseph
Love the Z CNC plugin , have a question though regarding masking in it . Masking by Alpha doesn’t seem to applicable to use or am I missing something ?
Hello - any movement on the Panel Loops Plug in update to 4r8? Thanks Joseph, you a beast
Joseph, thankyou to you and the development team for the Intersection Master plugin.
This is absolutely perfect for adding regular radiused edges to boolean intersections of complex surfaces.
Fantastic work.
Are you update the panelloop presets plugin for ZB 2021.5 ?
Atm the latest version from pixologic site produce a error:
Best regards,
Thomas
@TBAzB: The latest version from the Pixologic Resource Center should work with 2021.5.
https://pixologic.com/zbrush/downloadcenter/zplugins/
If you are still having an issue can you submit a support ticket at support.pixologic.com?
Thanks =)
-Joseph
Thanks for quick reply, Joseph.
I must contact the support.
edit:
Another plugin is caused the error.
Which one, Idon´t know
Thanks for you work, Joseph
Best,
Thomas
