Hello all,
Thanks for looking and hopefully helping me out here.
I can use the basics of the program, but not sure how this error is going to effect things in the future.
I did not use the auto update. I downloaded the installer and used that.
windows 7 64bit.
Issue 1
I get this set of pop ups before zbrush starts.
The program can’t start because MSVCR120.dll is missing from your computer. Try reinstalling the program to fix this problem. I reinstalled it. Didn’t help.
Zscript Note: Specified Execute-file could not be found.
SCRIPT: Sculpteo.txt
[FileExecute,[Var,gSculpteoDLLPath],CreateFolder,gSharedPath]
Zscript Note:…
ZScript skipped due to error in its content: Sculpteo
Issue 2
I am missing some smooth brushes. They are in the system folder, but when I open zbrush they cant be found in the brush folder. Also i loaded my custom UI and they are missing from that as well.
Please Heeeeeeeelp !!!
Cheers, Cad’
If you used the full installer then you probably just have a bad installation. Do the following:- Uninstall ZBrush and delete its folder.
- Disable your antivirus software.
- Download a new copy of the installer from https://pixologic.com/zbrush/downloadcenter/instructions/
- Install and activate.
- Enable your antivirus software again.
Thanks!
Regarding the brushes, I believe that some have been moved from startup to make room for other brushes that are new for the newest features. You should be able to find them via the Brush tab in LightBox.
If they’re brushes that you want to have all the time (which it sounds like you do, since they’re in your custom UI) you can move them from the ZBrushes directory to your ZStartup directory. Just remember not to have more than 25 of any given startup item type.
