Hi Michel, DynameshMaster is plugin created by Joseph Drust and Nick Miller; its an unofficial plugin but it has some really great functionality. You can find it here: http://www.zbrushcentral.com/showthread.php?177194-DynaMesh-Master!-unofficial-Information-Installation. It should work with Z4r6 but I haven’t tested it yet and the link doesn’t indicate any updates.
The Duplication-poblem is no located by me more exactly. It’s not a problem of Dynamesh-Master, I now got the problem without resizing before. It’s a problem after using bridge-curve to combine to parts of one subtool. I tried it out by undoing. Before using Curve-bridge, the duplication works normal, after using curve-bridge, the duplication resizes the duplicated object. I can show this problem with 2 screen-shots: Original and Duplication before and after using this tool.
Before using curve-bridge, both subtools are identically, so you can’t see a second one.
After using curve bridge, 2 steps later (one to create the first curve and the second to create the second curve for the bridge-function, the duplicate subtool is much bigger than the original and much more down in the canvas.
As I’m trying out this new version, (and coming back from a couple of months of having to work in other software) I realise that I desperately want a second viewport… same view if need be, only to a controllable zoom in/out …and in a stand-alone window that you could place anywhere, even on a separate screen,…please
Any master script writers out there fancy a crack?.. I’d even chip in some cash if there was enough of us wanting it?
I’ve just seen, that that after duplication, the too big duplicate subtool is one step forward in the undo-history immediately after creation. Hitting the undo-Button (Ctrl-Z) brings it to the correct size.
So duplicate and Ctrl-Z in the new subtool after duplication does, what only duplication should do.
Don’t see it as necessary. If you have 2 monitors you can do a quick screen grab and display it on your second one. Are you using the Axis plug?
Not the same thing really
… sometimes working at less-than-full scale can have an impact on what you have at full scale,
and a screen grab couldn’t reflect what is happening real-time at separate scales
Hi everyone!
I have a problem with Goz all of a sudden…
Goz is not running in ZBrush4R6 and other program as well, include 3D Max2014
I tried to reinstall Goz in ZBrush but no result :
In the Max script editor :
– Error occurred in StartConnexion(); filename: C:\Program Files\Autodesk\3ds Max 2014\scripts\startup\Macro_GoZ.ms; position: 66924; line: 1935
– Frame:
– Error occurred during fileIn in #C:\Program Files\Autodesk\3ds Max 2014\scripts\startup\Macro_GoZ.ms; line number: 1935
>> MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max 2014\scripts\startup\Macro_GoZ.ms Exception:
– Runtime error: dotNet runtime exception: Invalid directory on URL. <<
I’m not pretty confident with the scripts, could you help me fix this problem?
I would appreciate any help
Well first of all I was just saying it would be a nice feature, I already know it doesn’t do it…
…but what I find interesting is that when you hover your mouse over a tool a 2nd window pops up with same object, same rotation… now if we could just keep it open
Major drawback I see is that all windows must be within the ZBrush ‘main frame’. For it to be really useful, you’d have to be able to position it on a second monitor.
Hi guys!
Could you help me to fix the problem Goz to Photoshop Extended?
Do you know what this window means?
Because I’m really don’t get it
I’m getting this error when I try to store config and/or save the hotkeys. running OS X 10.8 on a macbook pro. Any help would be great!
Looks like it could be related to file permissions. Make sure the folder can be written to.
Actually, this started happening after I changed the permissions in users/shared/pixologic to read/write for everyone. Should the permissions have a different setting?
I’m on Windows and normally don’t have these problems…Did it work before you played with the settings?
Yes, it worked before. I may have to play around with the settings again.
That fixed it. Changing my permissions to read/write caused the problem. Changing the permissions back to read only solved the issue. Thanks for the helps guys.
Hi. I click on the installer DMG, it loads on my devices panel but when I click on the installer it asks for my computer’s password and then nothing happens. On a iMac 10.6.8. Any help would be great.
Ok,
I was having a number of plugin problems, and in the end had to nuke Zbrush and do a total install of 4R6. Everything has been peachy keen. I just tried to use Transpose Master with the Zsphere Rig, and I get this message:
So I have been pouring over this thread to see if it has been an issue with others and read that a quick cure is to use the Zscript from 4R5…But I nuked everything because I had to do a clean install of4R6. I didn’t back up the entire 4R5 applications folder, just the stuff I needed, like Brushes, alphas, etc…Downloading the plugin has been discontinued at the Pixologic Download center…So…
What am I to do???
I have tried this with several different files, and the results are the same.:mad:
It shouldn’t be necessary to install a previous version. I’d appreciate it if you could let me have a project to test as I can’t reproduce this error (I’ll PM you). In the meantime you could try this:
- Save out the model that you wish to pose as a ZTL file by pressing Tool>Save As.
- Create a clean project by opening the DefaultCube ZPR from the Lightbox Projects tab.
- Load the model you saved at (1) by pressing Tool>Load Tool.
- Use Transpose Master to pose you model.
