Use this thread to post questions regarding any issues you might encounter with ZBrush 4R2b. Please be sure when posting about unusual behavior to follow the forum guidelines found here: http://www.zbrushcentral.com/announcement.php?f=101
This initial post will also be updated with answers for the most common issues regarding upgrading to ZBrush 4R2b as well as installation and activation. It will be updated as necessary. Should you encounter any problems with installing or activating 4R2, please check this list before posting in the thread or contacting Pixologic Support.
Please be aware that during launch week we experience incredible server traffic. It is not uncommon for multiple tries to be needed to get an activation code! Phone Activation will not bypass this issue – the support representative will get the same error message that happens with Web Activation. Simply be patient and try again later.
Q: What do do if my copy of ZBrush 4R2 does not have a Web Deactivation button?
A: Install the update. When you activate, you may get a message that you are out of activations. If that happens, click the button to View Activation History. This will list the activations counting against your serial number. You can then check off the copies you’re updating and submit the form. A Support ticket will be created with the info that we need to remove the lost activation(s).
Turnaround time may be a little slow. Under normal circumstances we are able to handle these requests within 1 hour during regular business hours. However, things get a little crazy during launch week.
Q: ZBrush says it activates successfully, then immediately returns to asking for activation.
A: Version 4R2b includes a number of changes to existing features. Your CustomUI most likely includes settings that are no longer possible in 4R2b. Simply remove or delete the CustomUserInterface4R2.cfg file from your ZStartup folder. You will need to do Web Activation again, but this time the problem should be resolved. You will of course need to create a new Custom UI.
