We are considering this problem, but we are lacking of information to find the cause of this problem. In fact, none of our Mac at Pixologic have this problem, from development to testing machines and of course, betatesters, except one since few days.
You have to take in consideration that tracking a bug that we can’t reproduce is not an easy task to fix and you will see that sometimes, weird stuff can cause a bug.
If you want, read this short story about this pen tablet bug (it helps understand things…), if not, please jump to the last part of the post.
The betatester who have this issue never had this problem under Snow Leopard and updating to Lion didn’t change anything until ZBrush 4R2b days. Then suddenly, the unusable pen tablet bug appears: the pen tablet have a big lag when it’s over the document, but not over the UI itself. Using a mouse doesn’t create such bug. The only way to reduce a little bit the effect was to disable the Preferences >> Performances >> Multidraw option.
Then came Z4R3, still the same problem and one day, I had a phone call from this guy: he found something strange which make ZBrush running like it should be with the pen tablet: having Steam (from Valve) running! Yes, having Steam was making ZBrush working perfectly! Shutting down Steam was automatically making ZBrush/Wacom lag back. Weird. Most of the time, such conflict happen in the other way: making a software running should interfere with another.
After few weeks, he had to format his Mac and did a clean install of the system (Lion) and the first thing he did was to install ZBrush and the Wacom last driver. Guess what, the bug was here. Then he installed Steam… nothing changed this time… weird (bis). Just the multidraw was improving things.
Of course, this problem appears for him when switching to 4R2b. Then it could mean that this release introduce something which could have created this problem. I asked him to install back ZBrush 4R2… the problem was still here.
At the day of today, we are still investing with him, but with no progress.
Then to help us in this task, and if you have the bug, please reply to this thread with these information. The more details we will have, the better it will help us:
- Mac OSX version. Ex: Mac OSX 10.7.4 Lion
- Hardware (processor model, Mac name, year of release, RAM). Ex: MacBookPro 2011, Intel Core i5 @2.4 Ghz, 8 Gb of Ram
- version number of Wacom driver. If you are not using a Wacom, please specify.
- Model of pen tablet
- Do you have Steam running and does it impact ZBrush
- Which Flash plugin version do you have? (Steam is using Flash on OSX)
- When this problem appears, when upgrading to Lion, or when upgrading ZBrush to a newer version?
Another thing to test: -copy- (and not moving) your ZBrush folder to the desktop and see if something change.
Thank you for your feedback!
small_orange_diamond
Jittery Strokes on OS X For some reason, processor priority appears to not be being set correctly for ZBrush or Wacom. We’re looking for a solution. Here is a workaround for now:
