I did not understand anything, but also thank you very much:o
ahahah
Cool! That is seriously wild.
I think that its good that you are not following the tutorial, its meant to be bent, folded, spindled, and mutilated⦠and stuff like that.
Ohhhhhh! Ok, that helps a LOT.
Thanks!
GRIN!
Iām not surprised, this last stuff was sort of spasticā¦
However, which stuff? The videos, the balls of string or both?
LVXIFER!!
Very Cool!!! How did you make those string letters?
Love this thread! Itās like a ZBrush rabbit hole I never expected to fall into. But this exploration of edgeloops is coming up with some wild and wonderful results. I myself am playing along (on the sidelines) and enjoying the results. Your idea to turn your āstringsā into insert meshes and drawing with the results are brilliant. I can imagine you making a series of IMMs based on a string-like theme and mixing up the string results a little bit. Using this technique, one could certainly string together an alphabet or virtually anything for that matter.
Great posts here! Thanks againā¦the Youtube examples. They really help explain the methods.
What about fibermsh?? Do you guys think, will be possible to āwrapā around the āalphabetā ?
Does anybody know a good place to download fibermesh presets?
Iām still confused how can I āwrapā the strings around the lettersā¦
Thankās for help me!!
Cool!! Can you make the fibers āstickā to the surface of the object??
I lost the video again, the Deformation Pallet crashed ZBrush.
GRRR.
Canāt wait to see it!! What about the letters?? Do you think Lvxifer can help us?
heheā¦
ā¦must stop crashingā¦
Since I canāt seem to make a video I have been experimenting instead. The fibermesh thing is great and I figured that the next obvious thing was complicated IMM brushes.
I will try to make the video again tomorrow.
I will be waiting⦠Thankās for the effort.
Maybe you should try first with simple geometries, but I still like to see how we will be able to make the letters āwrapā around with cables or wires.
From the first video I donāt understnad if it will be possible to create different shapes(like letters).
I would lie to see your process and have a good idea how worksā¦
Thankās again and sorry for asking a lot about this topic.
Goshā¦
Iām sorry.
I ate some letters from my last post.
I mean I will LIKE to see how process to create the letters will be possible to do itā¦
Sorry about it.
Something like this
Wow!! Yeah!! How?
Check out this post http://www.zbrushcentral.com/showthread.php?170908-SpaceMan-s-SpaceBook-Journal-On-ZBrush&p=978449#post978449
post number 152 and see if that helps.
Hi again , Maleaying I like visiting your corner, also the other fellow to be learning, seeing I KNEW 2.5, I had a big smile. I think the phenomenon is called Serendipity. I like also the fractals, but is very difficult make a physicall.This design made five years ago to see a sunrise. I think also about drugeons .
Congratulations
Que bonita pieza amigo Meleayea, exelentes efectos de color.
Just wanted to thank you, very nice technique. I was looking for something like this since like forever.
Anyway⦠keep it up.
