MakingMonsters and lovin ZBrush
Monstermaker: This image you are having problems uploading. I had lots of trouble uploading one of mine once. It seemed to resolve itself when I reduced the size to under 1000 pixols in either dimenstion. Of course this may not be the same as your current problem.
nil
Monstermaker,
I dont know much about this either but have you tried making the file size smaller ? - ‘save for web’ at a lower quality in photoshop if you have it.
You are certainly building the tension/anticipation for your next post very well! Looking forward to it !
H
Ok Monster
A signature is a space that this and or other bulletin boards(forums) allow you to used to add quotes or like I have done add links to my favorite zscripts or add your link to your own website kind of stuff. You can find options for it in the User Options link just under the Zbrush url line above, next to FAQ.
Mine is all those orange names beneath this message…Psnap is there.
By default (see preferences menu in zbrush) zscripting is automatically on so if you open zbrush and start working it is recording your steps. You can set it to be off. Then you can soley use the zscript menu to record, stop, save your actions in any manner you wish. There is probably some info and how to’s in the help menu in zbrush.
hope that helps some.
Superb skull, great detail. I like your previous posts too.:+1:
Here’s a way to make the"hole" that was discussed above-
Isolate and then hide the polys near to where you want the hole-
delete hidden - which leaves you with permanent holes-
isolate and edgeloop the poys surrounding the holes for a little extra geometry and then just ‘tuck’ the open edges round into the hole until they
meet up inside.
But just coloring it dark works as well with a lot less trouble.
To see a Zscript… just go under Zscrip>load>file’s name…
Very artistic image by the way!:smiley:
Just wondering, If so me too! 14 years Pro.
There’s a few of us out there :slight_smile:
(Some us formerly…)
I saw David Miller at the first users group meeting…
~Mike D.
Damn Monstermaker, you should get a job in film FX or summat similar, you’d probably do ok :smiley:
Seriously though, been a big fan of yours since American Werewolf, love your work here. Unfortunatley I was at the back of the queue when talent was being handed out :cry:
All your work looks fantastic,
Im big on the monsters… :+1:
keep at it… its only getting better.
