Issues with Ztext plug in
Hello all,
I’m brand new to the forum but have been working with ZBrush for about 7 months. The issue I’m having is that when I go click on the EZtext Plugin, Zbrush want to initialize. However, when I click yes, I get and error saying abnormal termination. Any ideas to a fix?
I’ve never heard of it. You didn’t hear about ZBRUSH 4R5?
When I click initialize and continue, I get the error pictured above.
You really should upgrade your copy of ZBrush. Where did you get the plugin? Will it work if you do initialize? Is there a text version of the file or just a.zsc file?
Ok, I’ve upgraded to 4R5 yet the problem persists. The plugin contains a ZSC file and a folder which consists of a ZTL file, a text doc. as well as several BMP for alphas. The error code keeps suggesting that the issue is in prefereneces under ICOLOR-ZBUTTON. However, I can not locate such a setting.
Everything else works perfectly. Just wish I could use the plugin to create 3D text quickly.
I got the plugin from "CreativeCrash.com if I remember right.
You appear to be missing an essential text file…
In this thread is a set of letters as well as numbers as insert brushes. You’ll have to look for them.
http://www.zbrushcentral.com/showthread.php?170167-Insert-Multi-Mesh-Repository
Here’s a link to the plugin in question:
http://www.creativecrash.com/zbrush/downloads/3d-fontmaster
