[attach=222814]Banner[/attach]
Note: all plugins are now included with the ZBrush 4R7 installer. If you did not install a plugin then run the installer again.
For the latest information see the online docs here : http://docs.pixologic.com/user-guide/zbrush-plugins/
Image Plane 4 provides an easy way to load images into ZBrush for use in texturing and polypainting, as well as for background reference while modeling.
- Easily load a background image when a model is in Edit mode.
- For ZProject polypainting, quickly change the background image without leaving Edit mode.
- For Projection Master texturing, the image is automatically wrapped onto your model.
New in this version of Image Plane is Reference Views:
- Store 8 different views of your model
- Store a different reference image for each view
- Adjust the model transparency
- Quickly cycle through the views
- Save and load Reference Views projects
This plugin requires ZBrush 4.
For instructions about using Image Plane 4, press the Help button in the Image Plane menu.
Frequently Ask Questions
Q: Where can I get help for Image Plane 4?
A: Post your questions in THIS THREAD.
Q: Doesn’t Spotlight do all this?
A: Spotlight and Image Plane do similar things but in different ways. Image Plane 4 has been released so that you can use whichever you prefer. Also some tutorials for earlier versions of ZBrush require the Image Plane plugin, so with this update those tutorials are still good.
© 2010 Pixologic, Inc. All rights reserved, Pixologic and the Pixologic logo, ZBrush, and the ZBrush logo are registered trademarks of Pixologic. Various patents pending. All other trademarks are the property of their respective owners.
