here is my brush Cycl0r, you can use this script if you want do switch between 2 brushes again and again without typing every time the shourtcuts for the brushes…
how to install:
extract and put into you zstartup\zscripts folder or load manually via zscripts panel,
you will now find the script in the zplugin panel,
assign shortcut if you like…
when you use the Cycl0r there are two base brushs selected, activate another brush and use the Cycl0r again and u will switch the last brush you have used…
hope you like it…DarksBrushCycl0r.zip (1.92 KB)
small_orange_diamond
