Hello ZBrushers,
I’d like to share this concept illustration I did on a wip-model. This was basically one of a few quick render tests, but might as well serve as an illustration. (As you can see in the sketches below there is still missing a lot;))
[attach=189175]demon-web.jpg[/attach]
[attach=189176]model_sheet.jpg[/attach]
This is some personal work and the creature is far from being finished,( due to other projects I am working on, I won’t find the time to continue working on it so soon). So below you can view the preliminary work that went into it and the difference is mainly that the creature will get hair (like tentacles) and will be clothed and armoured.
This was basically just a real quick thumb nailing phase (first pic) and after picking up the guy I liked most, I did some more detailed sketches and variations on the face. In the end I decided to go with the less detailed and more suggestive face design, because I favoured this kind of holow mouth/face.
All the additional designing will be done in the sculpting phase, which saves a lot of time. A digital concept can be done this way in a few days and this is the reason why ZBrush is absolutely great for conceptual design. You can work really fast with it and on many occasions you can even skip the 2D concept design phase.(You can see the basic model inbetween the sketches).
[attach=189177]preliminary.jpg[/attach]
Crits and suggestions are always welcome :).
Cheers
Hard times indeed, great sculpt!
