your sculpt is looking good so far. Allow me to offer some suggestions on your anatomy (which is very close, but could use some “oomph”)
consider that, in general, when your model is looking directly forward, the distance from the bottom of her chin to her nipples will be very close to “one head height”. If they are lower, it can indicate an older woman or a specific ethnicity.
Also, the nipples do not point directly forward. They actually point slightly outward. If you were to draw a line from each nipple, to the center of her spine, while looking at her from directly above, the angle between those two lines is very close to 90 degrees.
Her breasts are lacking volume in the upper region. Inflate her upper chest area (above the nipple to the armpit) a little bit, and separate her breasts from eachother. Unless she is wearing some kind of support bra, her breasts are a little too close together right now.
from the standing side view… narrow her waist all around, and rotate her pelvis. Lean the top of her pelvis forward, and pull the bottom toward her rear. A woman’s pelvis is tilted more in this direction then a man’s pelvis is.
from the standing front… to emphasize the female form, you need to widen her hips. Where her leg bone fits into her pelvis needs to be broader to indicate that she has a pelvis wide enough to carry a child. Narrow hips indicate immaturity (under 14 yrs old) or a boy. Some women have narrow hips, and if that’s your intent, then so be it, but breasts like hers can only be complimented with more curvy hips and legs.
Just my 2 cents. Hope it may help.
