Some views and progression, still working.
Das ist der Welt Schmerz…
Looking great Daniele!
All the best for the holidays and a Joyous and Healthy New Year!
Cheers, David
Daniele, just… just… I have no words!
Thank you guys, another test (still work in progress…need to work on the cloths detailing , the metal parts, etc) just another rendering with mouth opened.
cool ! !
thank u
Leviathan | quick test inspired by Hellraiser and H.R Giger.
The Pentagram Cenobite in contemplation of Leviathan. Concept art inspired by Clive Barker’s Hellraiser and H.R. Giger. QUick test.
Impressionante! Awesome!
small_orange_diamond
Hi guys…i’ve a question , why i don’t see the correct transparency in this model ? i post the default settings too maybe the answer is there. Please help me.
P.S some time has passed since my last post cause i’m working a bit on digital painting cause
i want to combine the zbrush magick in it. For those who are interested i’ve make some works
during this period here is the link on my FB page, curious to hear you comments even if i’ve used Zbrush just a little
https://www.facebook.com/media/set/?set=a.10202563162827887.1073741840.1460779242&type=1&l=fece528ec9
I see no refraction at all, and I don’t understand the Boolean union you have set up, of course these are just guesses. I have had problems with the gel setting in modifier in the past… Sorry no real advice I’m just a newbie…
probably the trick would be to clone the model and flip it so you have the inside parts too—had to try !
Double
When 3D objects are drawn on the canvas and rendered, by default only polygons which face you are drawn. Pressing the Double button causes all polygons (including those facing away from you ; the backfaces -) to be drawn. Pressing the Double button has no effect on the objects true geometry, only on how it is drawn on the canvas.
I’m just trying to help.
Ciao,
TM
No the result i want with double button, here you can see a fast rendering in 3DS max with the same model…you can see the real transparency as in reality. Is this a limit of Zbrush ? Actually you see the transparency between two subtools and not on a single one.
…so nobody knows??
Some amazing paintings there!
Daniele, I can’t help much, tried it and seems working on separated tools only.
You’ll need to adjust the BPR Transparency.
:lol: I feel your pain. I about uploaded a .zpr with BPR transparency. 3 subtools. Didn’t manage what was shown in image above though. May play with it more later.
Thank you guys for trying to solve the problem…actually seems a limit of the software , at least an opacity option to see what is back/inside on a single model could be enough but nothing!
The Mealea method is …mmm…i don’t know…crazy as her ahah
