OK - finally as promised - character rig 1 to test out. Should work on PC or Mac. Been tossed back and forth so much, not sure where this particular version started - based of my Frankie Jr., from way back, but that will be worked out next.
If this works for all, it will simply be a starting point, a base. So some feedback is in order. Stretch limbs, scale, whatever, then sculpt.
As you can see from above images, a lot of controllable detail is possible. Magnets are present as well. Mouth works, detailed mouth, face, nose, etc. possible and easy. Well as long as you follow rules, basically if it messes up YOU did something wrong.
I’ll post some other characters soon to see where this all leads.
Everyone is free to do as they like with these, although some recognition would be great for my over inflated ego.
Don’t break the morph, I’ll explain the process later. Increase the levels to what you can work with and sculpt. Then pose so we can see. Remember the rules for bending - zspheres in 1 axis only, or you’ll get a mess.
Let the insanity begin…
EDIT: I made a small change to the feet…
