While we wait for the new Zbrush and the opening of the holy Zscript Grail hopefully you will find some use for the new Zif Click Beta.
Zif Click, will let you Point and click new zsphere nodes, or draw them with a brush. It will also enable you to copy part of your model and then replicate it anywhere else, even onto another separate model. Zif Click will allow you to work with Branches of the Zsphere Tree, which means the node that you have selected and any associated Children of that node. You can Copy, Move, Rotate, Delete, Transverse or Scale that Branch independently of the rest of the model. Zif Click will also let you change the Root Node of your object. Control the Membrane, Twist and XYZ Resolution of nodes or Branches of nodes with a click of a buton or menu.
You will be able to precisely Scale, Space, Rotate and Move individual Nodes or Branches of nodes. This is very difficult to achieve with precision when creating Zsphere models by hand.
Not sure how this new interface works but be sure to get the Zip file and extract it to your Zscript Directory
Thanks Digits, I’ve been looking forward to this.
