Here is the finished Robot Tool Kit. Note that there are no hands. I invite you to create whatever mechanical hooks, pinchers, or what have you to equip you robot with “hands”.
- RoboHeadRevA.txt
RoboNeckGuard.txt
3)RoboChest.txt
- RoboPelvis.txt
- RoboAb.txt
- RoboJointA.txt
- RoboJointB.txt
- RoboThighRevA.txt
- RoboFoot.txt
- RoboShin.txt
- RoboEyemap
A couple of notes:
The RoboThigh is a bit funky. Run the script and then you can move the object around. If you try to draw another one it will go wacky. I will try to get this working more smoothly.
I originally made an eye script BUT the script does not record custom colors so it was useless. So I provided the next best thing…the actual eye map. Just grab it off the screen and convert it into a BMP or PSD file wrap it on a sphere in ZBrush and you’ll be ready to go!
To create left and right body parts (arms, legs etc) just select the object and use the MIRROR command in the deformations pallet. Set it on XYZ.
If you have any problems with these scripts please let me know.
To finish your robot just add wires, tubes, various other doo-dads and voila! Instant mechanoid! I invite you all to make a bot! I will post my own shortly.
