This thread is intended as repository for useful small zscripts, plugins and macros. Sometimes there’s a simple zscript solution to a problem or need that may not warrant a major plugin but will none-the-less be useful to users. If you have written such a zscript, plugin or macro please share it here so that users can easily find it and benefit. Thanks!
Note: some of the plugins or macros posted here may not work correctly with ZBrush 4R3. Those that have been updated for 4R2 will say so.
Index
Large Menus (this post - see below)
Proxy buttons for Toggle Symmetry, x, y, z, r and Enable Customize
Lasso - Paint mask/selection toggle
Beta Turntable Plus for ZBrush 4, 4R3, 4R6
Flip UV’s vertically on import and export
Y Axis Rotation - in increments
Init ZBrush and load Startup Document
Materials to Texture Map (updated May 29 2012)
Large Menus
This is for those people that find the ZBrush palette titles a little small. It’s a set of buttons that can be added to a custom interface to give access to the palettes. The images can be edited to suit the user’s requirements.
Unzip and put the Large_Menus.zsc file and MenusImages folder in the ZStartup/ZPlugs folder. Restart ZBrush and there will be a Large Menus menu in the ZPlugin palette. When creating a custom interface, the buttons can be Ctrl+Alt+dragged to where you want.
Note that when a palette is open in the right or left tray the ‘large menu’ button will do nothing.
