Hi
This tutorial describes one of the methods that can be used when modeling a 3D object. The key points within this tutorial are the method of subdividing a 3D object in order to get higher resolution mesh and the use of the editing curve and its impact on the resulting surface.
Rendering Mode Note: I usually choose the RENDER:FAST RENDERER mode when I model a 3D object. This mode is faster than the preview renderer mode and by ignoring any material information that you may already have on the object, it reduces material-shading distractions.
Select the FAST RENDERER mode, and letās startā¦
1. We will be using the Sphere3D tool as a starting point. Select the Sphere3D tool. Activate the TOOL
MODIFIERS
SYMMETRY
X mode. Set Tool
MODIFIER
Deformation
Initialize
HDivide=64 and VDivide=32 . We start with a relatively low-resolution (polygons count) mesh because it is much easier to mold the base shape of the head when there are fewer polygons, further more, less polygons means faster interaction speed. As we add more details to the model and we find that the current resolution is insufficient, only then we may choose to increase the mesh resolution (either globally or only in the area that requires higher resolution). In this example I have turned off the TOOL
MODIFIERS
SH and SV which disables the subdivision renderer. We do that because you may find it easier to model the head when the object is faceted and you can easily see the actual polygons. When done with the modeling session, you may reactivate the SH and SV in order to get a smooth surface. Now, draw a sphere in your canvas and rotate it such a way that the poles of the sphere are pointing up and down (and not in/out, as it is drawn by default). We choose this orientation of the sphere because it will make it easier to align the nose/eyes/mouth to the polygons grid. After you have drawn the sphere in the canvas, enter EDIT
DRAW mode and draw the front features of the face. Switch to EDIT
MOVE mode and use push/pull actions in order to deform the sphere into a head looking like object. Notice that when drawing the front features of the face, you should try to align these to the existing polygons grid (which is the reason that we have turned off the SH/SV).
2. Continue editingā¦
3. Continue editing until you get to the point that you are satisfied with the overall shape of the head and ready to add finer details.
4. Increase the mesh resolution by using the TOOL
MODIFIERS
DEFORMATION
Divide function and then apply TOOL
MODIFIERS
DEFORMATION
Smooth at 100% once.
5. Continue using the EDIT
DRAW and EDIT
MOVE mode until you get to the point that are satisfied with the overall shape of the head and ready to add the finer details.
6. Increase the mesh resolution by using the TOOL
MODIFIERS
DEFORMATION
MODIFIERS
DEFORMATION
7. If you feel that you would need even higher resolution in specific areas then you can use selective masking before applying any further subdivision. In this case, I opted to increase the resolution in the eyes, nose, mouth, and ears.
7a: In order to apply the masking, you need to be in EDIT
DRAW mode and holding the ācontrolā key while drawing in these areas (Note: the masked area is drawn darker than the unmasked area).
7b: Use the Tool
Modifiers
Selection
Inv to inverse the masking. This will now apply the masking to the other areas and remove the masking from the area that we wish to subdivide.
7c: Apply TOOL
MODIFIERS
DEFORMATION
Divide once. Now the object has higher resolution in the eyes, nose, mouth, and ears areas.
7d: Press the TOOL
MODIFIERS
SELECTION
CLEAR in order to remove the masking and the apply TOOL
MODIFIERS
DEFORMATION
Smooth at 100% once. If you intend to model a young looking (smooth surface) face, then you can simply continue using the edit mode and add further details to you model. In this example, we are interested in creating a rough/old looking surface so we continue with the next stepā¦
8. The shape of the editing brush is by default a very āsoftā brush. In order to continue and model the face to have a rough surface we need to modify the brush shape.
The shape (fall off) of the editing brush has a significant impact on the type of surface that will be created!.
To modify the editing brush we need open the curve control which is located in the TRANSFORM
MODIFIERS sub palette. By default the curve looks like the image belowā¦
We need to modify its shape in order to get a sharper-editing tip. Click on the middle dot and move it up in order to get shape similar to the image belowā¦
Now the editing tip is ready, lets continueā¦
8a: While in EDIT
DRAW mode, draw on the model and youāll notice that the surface is losing its smoothness and becomes much rougher. You may need to adjust the ZIntensity and brush size in order to get the impact that you are looking for.
8b: a zoomed area of the face.
9. Continue editing, try using various editing curves, ZIntensities and brush sizes in order to get a better feel of the impact that these controls have over the surface.
10. Reactivate the SH and SV and we are done.
While working on an image, I usually end up modeling several variations of the main creature head. These models do not get to be used in the image, so here is a page with some of these modelsā¦
Notes:
1. You may even start with a lower resolution mesh (SH=32 SV=16)
2. If you have reached a stage in your modeling that the object has a lot of fine details but you are simply not satisfied with the shape of the model, you may want to use the TOOL
MODIFIERS
DEFORMATION
Optimize (once or twice) in order to reduce the mesh resolution and continue from that stage.
3. I usually use the EDIT MOVE mode when modeling a large area of the object, use the EDIT DRAW mode for fine details.
I hope that youāll find this tutorial helpful,
If you try this tutorial, please post your image/s and finding.
Pixolator
My head modeling technique is a little different than this one. Iāll have to give this one a try and see how it feels.
