Anyone seen a 3d printer cutup tutorial anywhere?
We finally took the plunge and ordered a Ultimaker 2.0+ extended.
I know how to cut things up in zbrush, but for things like limbs, you usually want one or more pins and a socket(s) to align parts properly. My Zbrush skills are a bit rusty from not using it for 6 months or so, and I’m sure there must be an easy way to add a pin, subtract it from one joint part, and add it to the ajoining part to be able to align parts a bit better.
Has anyone done a tutorial on doing this in zbrush anywhere?
I am interested in the same thing.
I have tried several methods for cutting up my models for print including outside software such as netfabb and meshmixer. However for ultimate control I would prefer to do it in Zbrush. I am looking for the best steps to take a model and dice it up so that I have clean flat mating surfaces that will register back together.
Thanks in advance
Here are three different methods you can try.
http://www.zbrushcentral.com/showthread.php?174566-Cuts-and-key-in-zbrush-4r4
https://www.youtube.com/watch?v=V9IADbFapXE
https://www.youtube.com/watch?v=BDasIVyxGPg
Thanks for the links. Greatly appreciated
Thanks! I just found out I’ll get my ultimaker 2+ extended a week earlier, so I need to bone up on these!
