Hi
This tutorial demonstrates a method in which a terrain 3D object is created by the use of 2.5D brush strokes and 3D alpha based deformations.
Above is the image that is generated by the script. The described method is quite easy to follow and it is very fast. The ZScript execution time is between one to two minutes (depending on your system speed). With this method, a terrain such as the one above can be created in an extremely short time. This method can also be used when creating a colorful terrain.
Click here to download the AlphaCentury ZScript
After extracting the included files, place these files within your ZScript folder and open the AlphaCentury.txt zscript from within ZBrush.
I hope that you?ll find this tutorial helpful
If you try this tutorial, please post your images and/or findings,
-Pixolator
Previously published ZScript
RustedGoldenIdol
Newer published ZScript
TextureMaster
I just finished running the script, and am in total awe. The technique is amazing, and has the potential to solve a lot of problems. Not only that, but it gave me some really cool ideas.
