I did a head, and put a sphere as the eye. When i try to fill it with a material the head get the same material. How do i apply a different material to each one?
the word you’re looking for is groups … then at the top there’s the the “Color” menu … inside you’ll find a “Fill” button. If you only have the (M) selected, it will only apply the material, If you only have the (rgb) selected, it will only apply the color. You should watch the starter vids again … in the Classroom … all this is there.
“Zubtool”…:lol: what’s that?
If you want a Material/Color to stay in a “subtool” do the following.
- Select the subtool you want to fill.
- Turn on ‘Mrgb’ button.
- Select the material and color you want to use.
- Go to ‘Color’ menu and click ‘FillObject’.
Now that material and color will stay in that subtool. It only looks like it is in the other subtools because ZBrush is giving you a live preview of the material. Select another material and see.
Repeat steps 1 to 4 if you want to
‘Fill’ another subtool.
Hehe i put it that way to make it funny. Thanks for your reply it makes sense now.
