zSphere Topology Problem
Hey there,
i hope i was not to blind when searching for this problem.
I am pretty new to zbrush and i am still doing one Tutorial after the other.
Next to Try to sculpt my Ideas or trying to particpate to some Challenges
The Problem i am running into several times is that when retopologizing some verts are not movable after creation.
What could be the cause for this?
Thank You. And Sorry if this problem is already discussed.
Best regards.
Sascha
Are they becoming masked accidentally? Which version of ZBrush is it?
Thanks for the reply and Sorry for replying that late.
The Version is ZBrush R3.
I do not think that they are masked, because unmasking did not help.
Accidently i found out that when i turn Edit Topology off and on again, alle Vertices can be moved again.
I restarted ZBrush an loaded the unsaved tool. And the verts could not be moved. Edit Topo off and on again. And they can be moved.
Easy workaround to help myself, but how does that happen?
Best regards
Xypher
It happens if you save the model while Edit Topology is active and come back to it in another session. At least, that’s the cause I’m aware of. If you hadn’t done that, then you’ve encountered a new one!
This happens during one session without saving.
Another thought was that this only applies verts connected with unequal than 4 other verts, but it turned out that this is not the cause.
