Zsphere sketching mode error
  • I try to enter zsphere sketching mode by using shift + A, and I receive an error " Zscript note interface item could not be found, preferences interface document fade in… , did i not install the download correctly or, I have a feeling its just a windows 7 bug, but when I checked the forums most people running windows 7 say its great
It seems like there a Zscript missing, but if I load one of the Zsketch models that come in the default ztools shelf, the sketch mode works, but not all the brushes work. If I try to create a Zsphere from scratch and enter sketch mode nothing works.
Has anyone else had this problem
currently using Zbrush 3.1. Maybe it is smth doing with version, cause Shift A doesn’t work at all =\
ZSketch and ZSpheres II are features for ZBrush 3.5. They are not available with earlier versions.
yea I know, I am using 3.5, but the problem was I had 3.5 and 3.1 installed, that was the problem I had to unistall both and then re install 3.5 and now it works fine.
