Zsphere problem maybe
Hi
I’m after some advice on Zspheres when I create a Zsphere and press the “A”
button to look at the skin there is only half a Zsphere there, even if I drag a
new Zsphere out from the original when I check the skin the original Zsphere is still half missing but when I drag a new Zsphere from the side that disapears when I press “A” the original is ok am I doing something wrong or is this normal
perfectly normal
Sounds like you are zskecthing? The only time I have experienced what you are describing is when zskecthing.
I’m running 3.2 on a mac which as far as I know does’nt have Zsketch so i’ll go with goast’s reply of perfectly normal
Thanks for the response guys
