Zsphere help
I tried to post this in the zsphere forum but was ineligble for some reason. When working with zspheres all of a sudden the work will shrink completely and I can’t restore my work because it also disappears in my tool box. Whats the general concensus out there regarding this problem? The rest of my tools outside of the zsphere are pretty stable and I can work up to 9 million polygons with no problems.Has their been a general problem with zspheres that I have overlooked and if so could somebody point me in the right direction. Also this problem will occur with just 5 or 6 spheres so its not a numbers issue.
Thanx in advance!
Yep, apparently it’s a known bug (see this thread).
To get your model back, press A to preview the mesh, then F to frame it, then A again to toggle ZSpheres.
noticed the same issue… drove me crazy… press A and then F and then A again (as mentioned above) and you can continue… It will happen again, and again… but you kind of get used to the key sequence, and work around it.
