Zsphere Fly Away [workaround]
I don’t know if anyone else has this problem, but every once in awhile when I am building a model with zspheres the model will suddenly shrink to a tiny version of itself. Then, if you try to scale the model up, it will only scale up a little bit, and it is impossible to work with.
The workaround I found to this problem is to turn off edit, redraw the model on the canvas and delete the tiny one. Sometimes you will have to hit undo a couple of times before you redraw the model, or it will redraw it at the tiny size.
:+1:
What works for me is when I mask the entire model then ctrl click in an open space. Then I can continue working with no problems. Well I thought it was just me having this problem xP.
It’s a known issue. You can also turn on the preview, press undo, then turn the preview back on and press F to frame the model again.
This issue has been corrected in 3.12, and PC users will see the fix in ZBrush 4.
Can’t wait for Z4 to be out ><.
aww us pc guys have to wait till zb4?
