Zsphere flickering/clipping issue
When I am using more than 4-5 Zspheres to build up a base I run into an issue with flickering/clipping.
When I navigate around my model on the canvas, at certain points the entire model just disappears, the only way to make it re-appear is to keep rotating around it another 20 degrees or so.
This is making it impossible to model it correctly as in a lot of the angles where I need to make adjustments, the model simple goes invisible.
Is this a known issue? Is there some way I can solve it?
Thanks,
Tebs
new to me.
what version of Z are you using?
do you have perspective on?
can you make a video showing the issue (include the entire interface)?
