I’ve set up a zsketch various times with success, but I don’t know why sometimes the zsketch won’t stick to the subtool in the other layer. Here’s my workflow…
I import my object – in this case a head and bust to use as a surface to sketch some hair.
I append a zphere and scale it down some so it doesn’t get in the way.
I select the zsphere subtool layer and activate “edit sketch”.
I start drawing, and the zketch tubes don’t lay on the head surface. They get painted inside the geometry. SOmetimes, it’ll only sketch on the small zsphere I scaled down.
Sometimes, it works properly, but less often than I’d like.
Sometimes, I can’t zsketch after a few minutes and have to try again with a fresh scene.
Am I doing something wrong?
