Working great for me Thanks for this.
Hey TVeyes,
Much appreciate the new gizmo for xyz adjust!! Had it now since you put it up and man I gotta say its plugins like yours and others that push zbrush that much further along. I did run into a small snag at the start, when I did extract all into the zplugs folder it actually created another zsphere tweaks folder and put the items into it. Didnāt think much of it at first until it wouldnāt work. I just dragged the items from the zip file and it worked fine!!
im having some problems to use it on 301? I followed the istall instructionsā¦butā¦is that normal or the its me? :rolleyes:
is there a 3.01 or d you mean 3.1??
Iāve installed on 3.1 as wellā¦no problems. Please explain your problem with a little bit of detail so we can help
the new version⦠worked wellā¦
Wow! Excellent work TVeyes
This is going to come in EXTREMELY handyā¦all over again
Many thanks for recompiling this must-have plugin again!
cheers
Chris
any chance you can add the ability to change the parent zsphere, erm i mean root sphere
Thank you for the kind words everyone. I hope it adds a little extra to your zsphere modeling. I am looking forward to how you use the extra options (coming soon).
Spaceboy412, good idea, I think Digitsā had a way to do that in one of his scripts so it should be possible even if it requires reconstructing the zsphere chain.
I just realised that I never replied to you ragarding the new version of the plugin. Sorry about that. I am in the middle of swapping over to Mac and setting up bootcamp to run Zbrush.
Your plugin works well and I wont be so slow in replying next time.
Looking forward to the new features.
Cheers
Mike R
I am getting this problem when I run the activate the script ākā. Any ideas what I am doing wrong?
I unzipped all the files into
āC:\Program Files (x86)\Pixologic\ZBrush3\ZData\ZPlugsā
11 files total, correct?
goast666, the original version is not functional under Zbrush 3.1. Instead try ZSphere Tweaks which is posted a little later in this thread. I know, versions everywhere is a bit messy .
Mykyl, no worries. Regarding the next update the additional features and buggy zsphere commands are causing me some grief, so I guess I will just have to come up with some other features Any day now.
A numerical method of rotating ZSpheres would be a real great addition if it is possible? This is a very helpful item the way it is now.
Okay, I keep getting this error everytime I hit āKā over a Zsphere.
Zscript Note: Interface item could not be found.
5889
in...
[IHPos,5889,1]
I canāt seem to find a solution, Iāve tried reinstalling a few times.
Any help would be great.
Hi Steevz04, the XYZ Adjust zplugin is for Zbrush 2. For ZBrush 3.1 use the ZSphere Tweaks zplugin which is currently located in this thread.
If you happen to be using ZBrush 2 on the Mac platform you should us >> this << version. Yeah I know, this thread is a mess :o
Thanks TVeyes, really useful tool
Just a short note saying thank you to TVeyes for this handy zsphere script. Makes life with zspheres alot easier for a newbie like myselfā¦
Hello TVEyes
Thank you so much for this ZSphereTweaker plugin.
Now ZLife makes sense again
Cheers
kel
TVeyes
Thank you very much for ZSphereTweaks.
I have one question.
Is there a way to have ZSphereTweaks as a floating pallete?
:qu:
UL, until tveyes decides to do something like that you could in the meantime, create a custom palette and move all the buttons into that, then assign that to a hotkey and it will popup at your cursor.
tveyes, a few questions, did you ever finish your full version of this? i previously suggested a feature that Digits had implemented, the rerooting, he also had scripted the copy and pasting of zsphere chains, is this something you could add as well? i think digits is waiting for the SDK, which i donāt think will ever be released, so iām just asking you, hopefully iām not crossing lines or something.
Hi there!
Firstly thanks for the pixologic & community for the Zbrush program & plugins. It`s amasing what you can make with it.
- My question is:
It is possible to controll the zspheres numerically (scale, move, rotate). I am interested to controll individually and in group. It would be nice if I could for example straighten every zspheres in a chain; a part or everyone - the reason: It`s hard to controll with the pen.
>>>Another isue. It is possible to make morphs with zspheres? I could make nice morphs for example a tree growth, (in zsphere modeling state) or morph from one tool to another and then capture on a movie file. I tried with 3ds max but there has to be the same number of vertexes in the different state of morphs. My interest is morphing a complex model in another or grow from it. I made some complex models and I want to morph between the states, and the morph direction is wery important.
>>>I think it could be possible to use zsphere chains to build a moving path and then asign a tool to move along it.
It would be enough if you could direct me to a program, a method, or a weblink what deals with 3D morphs.
Sorry for language mistakes :). I am new to Zbrush so I dont understand scripting. Thanks again!
