Hello!
I’m just getting started with Zbrush
I want know What is ZScript / Tutorial Window? and how can I drag some brushes to it?
Thank you!
Hello!
Thank you!
The ZScript/Tutorial Window is the section of the interface at the bottom, below the divider. It’s where ZScript buttons and sliders will appear when the script is not a plugin and is loaded through the ZScript>Load button.
You can’t put custom interface items in the ZScript/Tutorial Window but you can put them in the section above the divider. You can read more about customizing the interface here:
http://docs.pixologic.com/user-guide/customizing-zbrush/interface-layout/custom-interface/
