Hi All!
I Whipped up a helpful little Zscript for Zbrush 2.0, it’s purpose is to make importing and using a Reference Photo a wee bit easier.
First off the script will prompt you for your reference image, after you select your image the rest is automatic.
The script will proceed and make a transparent material, flood your reference picture on the screen, and draw a reduced poly sphere on the screen… make a Polymesh out of it.
all you have to do now is mask off an area, subdivide, and start modeling!
This Zscript will work with any image… Try to keep the size square (128x128…512x512 etc.) for best results…
HINT:
If you don’t want to use the sphere, just press escape after the flood fill, and insert your own mesh, Zsphere, or whatever…
Have fun! And be sure to wear your safety goggles
http://s91842597.onlinehome.us/Refrence_load.zip
Have a good day everyone!
BTW:
I have included a few perfectly symmetrical photo’s for your modeling pleasure!
