|Hi Everyone,
Hya ZBer!
HI MARCUS!!!
I have a weird thing happening when I record and playback a ZScript, it goes sort of epileptic on me…
What I did was record the process of taking a Sphere3D from start to finish, in this case sculpting all the way to animating displacement maps and when I try to play it back it fails right off on the sculpting part.
I used only the Standard brush normally, with Alt, and with Shift for smoothing.
I turned it into a DynaMesh before I started sculpting.
Long before I get going it begins to twitch and hop around all over the place for no apparent reason. It adds masks when I didn’t use any and crushes areas and ignores others.
Then when I change a texture to an alpha I get an error.
I haven’t a clue what is wrong, so I did it again but somewhat less sculpting…
Same thing, spastic twitching but slightly better, then it does the texture to Alpha conversion just fine but leaves the Alpha palette over the screen, gets rid of the tool pallet from the right slot that it sits in (I forget its actual name) and fires up the movie like it should skipping the whole part I wanted to display in the first place!
That is the second file.
Are there things that ZScript can’t record or something? Am I doing stuff too fast?
Heres the files:
I would love to use this to make tutorials and stuff but something always goes wrong, this time I don’t think it was me, I have this process down and can do it without needing to undo or anything.
Anyhow, thanks for the help!
Cheers!
Mealea|
