When does the ZScript execute.(one that loads at startup)
But it seems to not actualy run the rest of the script if there is a button in it. Except that my variable all get set correctly. I am most interested in global routine calls.
How would you make it not re-run the script (mainly global routine calls). I am probably missing something simple here. I will try to post an example of what I am talking about if no-one understands me.
Now, this was a global routine and called globally,so why is it called when I press the button?
[RoutineDef,MyFunc, //** Define Routine/Function
[VarSet,t1,"Only Should Be Called On Load"]
[NoteBar,t1,.5] //** Set Notebar on load
,input
[VarDef,v1,0]
[RoutineCall,MyFunc,v1] //** Call Routine/Function
[IButton, //** Just Clicking here will make the Notebar Show Up
"ZScript:TestInitButtonFunc",
"Test Global Commands",
//** I would think this shouldn't run global Routines/Funcs
[VarInc,v1]
[If,v1>1,[NoteBar,"",0]]//** clear notebar
) that plugins load one after another on launch, then finally the defaultzscript loads. When one plugin (or zscript) loads it always replaces the previous one, so that variables are lost. So pressing a plugin button reloads it; it’s not constantly loaded.
ZScript
One more question about plugins/scripts :
